Changing restrictor ring??
Jamesy
I am bpu running 407bhp and seem to be making 14psi / 1 bar max.
I always thought bpu was 1.2 bar.
Does this mean my cw restrictor ring must be the 1 bar one?
And also is it just a case of if i buy a 1.2 bar ring i will automatically gain more boost and then some more power?? :)
Every car is different, yes you could put a larger RR in to get to 1.2, but
you should remember 1 bar is safer than 1.2 bar & your 1 bar on a cold moist day will rise, the same would be true of a car running 1.2 in summer then rising in perfect conditins.
mea by 20hp more depending in your engine condition!
407hp at 1 bar is very good!
mine is about 1 bar, on hot days i get around 0.98 on cold 1.08
edit-- but if you don't want to risk 1.2 rr you could always use a boost controller and raise it to 1.2 bar, i think it is the safest way!
Edited by trinitom (see edit history)
thanx!
so even with a 1 bar RR u can still run 1.2 bar with a b/controller???
yeah i think 407 is good for 1 bar - and that was before the fmic was fitted....
....do you think that maybe the turbos are hybrids? the previous owner thought it "might" be...is there anyway to tell? :)
thanx!
yes with 1bar RR you can raise boost with an EBC, about the turbos i don't know, the stock system normally produce around
400 hp at 1.2 bar assuming engine and turbos are in good condition.
I think the only way to know if they are hybrids is removing them and check if they have any steel components. “someone correct me if I’m wrong”.
i think i might go for a 1.2 bar RR then and just take it easy in the cold! ;)
Or swap it back to the 1 bar RR in winter. A lot of work but look at the alternative if you do not take it easy in the winter or you do get boost spikes! New set up tubbies and the labour to get them fitted.
Or as mentioned bite the bullet and get a BC fitted then you have best of both worlds and are in control as much as you can be. :) (still no guarantee but better than slapping a 1.2bar RR and hoping for the best ;))
yeah good point....
any suggestions or BC on a budget? but not a pony one :blink:
"if" my turbos end up being hybrids then i guess it doesnt matter if they spike a bit over 1.2 bar right??
yeah good point....
That is the word.....budget. Unless a trader has one 2nd hand.
Hybrids are usually rated to 1.4 bar. The hybrids on my old UK spec were Turbo Technics they were rated to 1.4bar. :)
just bought a Blitz SBC b/controller mate so will tweak it up to 1.2 bar.
I have been told that "if" i am running 407 at 1 bar and pre the fmic going in its likely i have hybrids...however im gonna fit the ebc then get it on AFR's dyno to see what power its producing.
Although the only way to be 100% is to have a look inside one - a cost and hassle i wont be bothering with just yet!! 1.2 bar will do fine...for now! :)
