Small Single Turbo Kit
Geo
XS Power T70 Single turbo
XS Power Manifold with good internal welds (see pics)
3 Inch Stainless Steel Xs-Power Downpipe
50mm Xs-Power Wastegate
Screamer pipe for Wastegate
All has done about 6000 miles guys, and has been only Run at 0.5 bar of boost. :D
Iv checked out the turbo guys NO play at all, manifold just needs a clean, all welds are good to go. No cracks at all.
Turbo -T-3 Flange 3” V-Band Inlet (compressor/cold side)Ø 102mm Outlet (compressor/cold side)(4”)Ø 65mm (2.5”)Exducer A/R 0.84 Compressor Style 0.70 Compressor major diameter Ø 84 mm
Pic of the setup installed
Wont split goes as One Kit
Looking for £280ono guys.
Right guys, i priced this as is. As i thought it was about right for this little Lot. Yes £280, but as its a bit heavy. it will be £300 Delivered. I reckon thats fair.
As Jamie said above it was a neat install done by Turbofit at the time, iv never gone above 0.5 bar on it, so it aint been abused that much. Iv no problems running this and its only out due to my bif build thread or i would have kept this Install in for a good while longer. :D
Trinitom you have OM mate.
I take it this is for a TT? how much power will you be able to get out of this?
Yeah for a TT. Iv no idea what the power would be, as i only had 440cc injectors installed and running 0.5 bar of boost, i reckon with bigger injectors and a good map, it would be 400ish or just over
