Larger injectors into Siemens 720cc collets.
RobSheffield
I want to fit larger injectors into the existing collets i had welded into my lower runners.
Trouble is nobody seems to be able to confirm its possible.
Are the Bosch 1000cc bottom collets similar in size to the Siemens?
When looking at aftermarket injectors from such sources, they didn't tend to specify the nose diameter so I'm assuming that's because they are all a standard size :) Nothing definitive though, sorry.
1000cc? Got plans, sir? :)
-Ian
Almost all Siemens and Bosch will be the so called 14mm type....referred to as "domestic" in the US.
Rob - if you're looking for a set of the modified Bosch 1000cc ones with the special top caps then pm me as I'm considering ordering a set - we may get some discount.
I guess you wont have seen my thread :)
Had a mystery problem, so going with a rebuild to be sure and confident in the engine. As part of the rebuild im going to go for a T71DBB with a billet wheel.
Sorry guv I've not really been looking at the build threads, don't get much time on here at the mo :) Nice turbo, should see a bit of power from that!
