Angarak Posted July 24, 2009 Share Posted July 24, 2009 Hi Folks, I went for a drive today to stretch the Supras legs, came back and noticed a water leak under the car (running off the cross member). I believe I have found the source of the leak, a small rubber hose coming from the bulkhead. I have attached a pic to this post. Can anyone confirm if this is the drian hose for the bulkhead? The water leaking from the car did not smell of anything, nor was it hot so Im *hoping* its just a drain hose as the car has been sat outside in the rain recently and not driven that often of late. Will be taking the black 'windscreen wiper' trim off tomorrow to investigate incase there are any blockage issues such as dead leaves, etc. Cheers Si Quote Link to comment Share on other sites More sharing options...
Angarak Posted July 25, 2009 Author Share Posted July 25, 2009 (edited) Ok, I dont think this is a drain hose for the bulkhead as rain water past the wipers would appear to drain via the wings and not the bulkhead. So, Im now facing the possibility of it being Aircon related Can anyone confirm if the hose is a drain for the Aircon system? I've had a look through my Supra manuals and cant see anything specific regarding the draining of the system should there be a leak. I've followed the A/C diagnostic check and everything appears to be fine, the A/C blows hot/cold air fine, but after another drive today to get engine temps up to normal operating levels, I still have a leak from the hose highlighted in my pic. Im pretty sure it is nothing to do with the engine. Edit I know the pic above is not that great, but its hard to get a good pic of it due to other obstructions. It is a small rubber pipe coming from the passenger footwell side of the bulkhead, it has a 90 degree bend in it, it comes out of the bulkhead about 3 inches before the bend and then down a 2-3 inches. Edited July 25, 2009 by Angarak (see edit history) Quote Link to comment Share on other sites More sharing options...
Kev.O Posted July 25, 2009 Share Posted July 25, 2009 Is the top arrow pointing towards something like a screwdriver, as I don't have anything like that in my engine bay. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted July 25, 2009 Share Posted July 25, 2009 Nothing like that here either.... Quote Link to comment Share on other sites More sharing options...
Angarak Posted July 25, 2009 Author Share Posted July 25, 2009 (edited) The vertical white line you see is a piece of painted wood - in an attempt to highlight the pipe lol. Just at the bottom of the white wood, you can just make out a grey bit, thats the clamp holding the rubber hose to the connection on the bulkhead. The upper red line points to where the pipe comes from the bulkhead, the lower red line shows the pipe just after it bends (in this pic, its bending to the right). Its really hard to get a good shot of it due to the narrow space and other obstructions. Edited July 25, 2009 by Angarak (see edit history) Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 25, 2009 Share Posted July 25, 2009 (edited) From memory, the stuff heading out of the engine bay from there, via the underside of the car, are brake lines, fuel feed and return pipes, and the EVAP emissions piping. It's certainly not aircon as they are solid metal pipes by the time they hit the bulkhead and are higher up. The only drain hose I know of lives under the battery tray. Edit - do you mean it actually enters the bulkhead through a visible grommet like the heater hoses do etc. or seems to disappear downwards as a black metal hard pipe? I'm putting my money on the EVAP hose from the charcoal canister. Still got one of those installed? Edited July 25, 2009 by Ian C (see edit history) Quote Link to comment Share on other sites More sharing options...
Angarak Posted July 25, 2009 Author Share Posted July 25, 2009 Im pretty sure its not the brake lines, fuel feed or return pipes. Not sure what the EVAP emissions piping is. I'll go see if I can get a better pic of it now, I've got a slim lamp somewhere so may be able to get more light down there to highlight it better. Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 25, 2009 Share Posted July 25, 2009 Did you catch my edit regarding the charcoal canister? Quote Link to comment Share on other sites More sharing options...
Angarak Posted July 25, 2009 Author Share Posted July 25, 2009 (edited) Here is a better pic. Note that the pipe now bends to the left on this pic since I rotated it. Ian: No I didnt see your edit till now, I do still have the charcoal cannister installed. The pipe goes into the bulkhead and not down it. Could it still be related to the cannister? Edited July 25, 2009 by Angarak (see edit history) Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 26, 2009 Share Posted July 26, 2009 You would not believe the piccy I just happen to have Is it bottom left in this? Quote Link to comment Share on other sites More sharing options...
Angarak Posted July 26, 2009 Author Share Posted July 26, 2009 I believe that could be the one bottom left in your pic ian (the one with the green marking on it), do you happen to know what it is? Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 26, 2009 Share Posted July 26, 2009 I believe that could be the one bottom left in your pic ian (the one with the green marking on it), do you happen to know what it is? Absolutely no idea, never knew it existed until now Quote Link to comment Share on other sites More sharing options...
Jimmer Posted July 26, 2009 Share Posted July 26, 2009 Looks to me to be the A/C drain hose, it allows the condesation that occurs due to the warm humid air coming into contact with the cold surface of the Evaporator drain away. Try going for a drive with the A/C off and see if it still happens. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 26, 2009 Share Posted July 26, 2009 Looks to me to be the A/C drain hose, it allows the condesation that occurs due to the warm humid air coming into contact with the cold surface of the Evaporator drain away. Try going for a drive with the A/C off and see if it still happens. Agreed. Quote Link to comment Share on other sites More sharing options...
Angarak Posted July 26, 2009 Author Share Posted July 26, 2009 Cheers everyone, will wait for a nice dry day to come along (im sure we have some left) and will take it for a good drive without the A/C to see what happens. Quote Link to comment Share on other sites More sharing options...
Homer Posted July 26, 2009 Share Posted July 26, 2009 Looks to me to be the A/C drain hose, it allows the condesation that occurs due to the warm humid air coming into contact with the cold surface of the Evaporator drain away. Try going for a drive with the A/C off and see if it still happens. Had a look earlier and can confirm this is correct Quote Link to comment Share on other sites More sharing options...
