filler needed
sprag5
Any pics? At a guess I'd say try and heat weld it (if you can) If not then use a small alloy plate pop riveted to the back of the crack for strengh, then use a good filler to smooth the crack out, make sure you V the crack open to let the filler bind and make a good repair.
Thats a start anyway. Good luck.
Dave.
i no haha but i think i might give it a go, i wont learn unless i try
thanks dave will give that a go first
I'm all for giving it a go bud, i did the same with my MR2, but get someone who knows what they are doing to show you the ropes. I took on quite a big task with the MR2, with a little help, and it all came out great. If i didn't have someone showing me the basics it would have been a disaster.
Make sure, if you are using filler, to re-inforce the split, as per supraloopy's suggestion. This is absolutely vital if you don't want it to crack after the first mile.
