Transmission oil coolers
adi
I may have to fit an oil cooler for the auto box. Can anyone suggest what type i should fit on the 1JZ (for the sake of argument its virtually the same as a 2JZ, the gearbox is virtually the same as well).
Can i get away with just fitting an air cooled one? Will it *have* to go in the water line?
Does anyone supply these on here? What about cost ? i can get my hands on an air cooled oil cooler (like a little radiator really) is there any reason why i just cant fit this in the oil lines?
cheers for the help.
adi
Guest Martin F
adi
That's exactly what you're after.
Guest Martin F
You're not going to achieve warming of the fluid like the stock system without a lot of trouble. As i said in my original post most people don't bother and just rely on an air type cooler.
Guest Martin F
Hmmm now that's tricky.
For best cooling it should be at the front, but then you would mask part of the rad. If you put it behind the rad then obviously the airflow wouldn't be quite so great.
IMO i would put it in the easiest mounting location first and monitor temps and take it from there.
