speedo reading inaccurate
Rob_Mitchell
Have you changed the dials on the clocks or have the needles been off at any point? The clcoks are precisely set at the factory, and taking them off completely throws the readng out the window. I had this with my MR2, took about an hour of trial and error to get it right again!
If you're doing around 30mph and it's indicating 40mph, then there's something wrong. However, I know when my speedo is showing 100mph, really the cars doing 93-94mph (on satnav).
All speedos are slightly out and always - well, should always - read fast.
it will also depend on the combination of wheels and tyre sizes.
For instance my tyres are a smaller profile compared to what i should have to make the roling size correct. So at about 70 or so it off by about 7-8 mph, and about 100 its about 10mph out.
I thought the speedo came from the gearbox? I'd imagine there'd have to be some odd combination of wheel and tyre sized to make a 10mph difference at 30!
How long has this problem been going on mitchell?
Yeah but if your wheels are smaller. your going to need more turning to go at the same speed as someone with bigger wheels... hence the speedo being off... I think.
Correctamundo.
Change the rolling radius, change the distance travelled per rotation of the wheel, drive-shaft, prop-shaft, flywheel etc, etc, etc
I bought wheels for my MR2, they came off a supra. Tyres were good so left them on. Made my speedo read accurate.... not a good thing.
Yourself, @ at least 100mph, along to benny hill music.
Remember to record it all :D
You have to take the needle off, put it to around -10mph and go for a drive, see where it is then. Then just keep making adjustments until it is accurate again. Very repeatative and annoying!
You ruined it :(
How do you do that though? Surely when you are at a stop the needle is at a stop?
You have to turn the ignition off to de-energise the clocks. You can't do it with the engine on! :lol:
Yip.... so......
The speedo is reading 40mph when you are only doing 28mph. You want to lower the needle by approx 10mph. You turn the engine off and the clocks re-set to zero... how do you set the needle back 10mph with the stop in the way?
Yip.... so......
You lift it over the stop... :rolleyes:
Sorry, let me explain a little better...
You take the needle off the clock, put it back on at around the 6 o'clock possition, then wind it clockwise up to and over the resting pin. This should put some tension back in the spring which controls the needle, so 30mph will put enough force on the needle to push it round to the 30mph mark.
Note: Taking the needle off will result in ALL the pressure being taken off the spring, so you will have to wind it back further than I previously stated. I just got really quick at moving the needle after an hour of tuning it so I could make small adjustments a little better.
I've always been confused by this. On bigger wheels the tyres are a lower profile, so wont they be around the same size as a smaller wheel with a higher profile tyre on?
Thanks for the speedo info, sounds like a pain :blink:
If the sizes are correct then the rolling rad shouldn't be changed. Happens a lot though, buying a set of wheels with the wrong tyres on. As i said, happened with me :)
  • 2 weeks later...
Guest bennyessex
When I owned that car I used to think 30mph felt very slow! I guess thats why.... Hvae you found a solution yet? Could be to do with the converter as its an import?
