L33 Posted February 23, 2010 Author Share Posted February 23, 2010 not a clue....pretty stumped to be honest, like i said you can clearly see the 2 sensors, and if one was faulty then it wouldnt show a reading not show a simular one? i havent pulled the gauges out yet or disconnected from the defi control box yet like i said one is in oil temp and one in water temp but that shudnt matter?! Link to comment Share on other sites More sharing options...
Scott Posted February 23, 2010 Share Posted February 23, 2010 As far as I know a temp sensor is a temp sensor Link to comment Share on other sites More sharing options...
dude Posted February 23, 2010 Share Posted February 23, 2010 well ive found the problem and sods law it only dripped a few times when on the ramp even tho we left it running, reved a bit and then cooled down but we didnt need the drip to see what the problem was the gearbox sump gasket appears to be perished and a little bit of sealer seems to be flaking off! around the fixings the gasket is sticking out and seems like its falling apart. can push it with you finger and its spongy and small bubbles of oil are coming out will get hold of toyota and order a new gasket so i can change that. the toyota garage is next door to my office which is handy stil a nusiance having to do this and cost more money They should not have a gasket on at all dude, the gearbox sumps are silocone sealed from the factory Link to comment Share on other sites More sharing options...
L33 Posted February 23, 2010 Author Share Posted February 23, 2010 o..... so what do i do to stop the leak? more sealant around the sump? Link to comment Share on other sites More sharing options...
Scott Posted February 23, 2010 Share Posted February 23, 2010 o..... so what do i do to stop the leak? more sealant around the sump? Ahh, its the same as the engine oil sump then. Take off the sump, remove all the old tat and then re-seal it Link to comment Share on other sites More sharing options...
L33 Posted February 23, 2010 Author Share Posted February 23, 2010 o result cheers Link to comment Share on other sites More sharing options...
dude Posted February 23, 2010 Share Posted February 23, 2010 Make sure you use a good quality sealer not cheap stuff dude, trans fluid makes a horrible mess. Link to comment Share on other sites More sharing options...
L33 Posted February 23, 2010 Author Share Posted February 23, 2010 yea and that stuff aint cheap so i will reuse the stuff my family friend mechanic is getting said its about 20 quid Link to comment Share on other sites More sharing options...
dude Posted February 23, 2010 Share Posted February 23, 2010 yea and that stuff aint cheap so i will reuse the stuff my family friend mechanic is getting said its about 20 quid Make sure both surfaces are nice and clean and do NOT put loads on, it will squish into the sump and can block filters etc. Link to comment Share on other sites More sharing options...
L33 Posted February 23, 2010 Author Share Posted February 23, 2010 the pics dont make the turbo look as big as it actually is! and a bit of a update on the breather system, the left side of the rocker cover goes into the catch can and the right side goes throught a non return valve and then into the intake on the right which apparently is fine even tho its silicone Link to comment Share on other sites More sharing options...
L33 Posted February 23, 2010 Author Share Posted February 23, 2010 Make sure both surfaces are nice and clean and do NOT put loads on, it will squish into the sump and can block filters etc. ok mate thank you Link to comment Share on other sites More sharing options...
L33 Posted February 24, 2010 Author Share Posted February 24, 2010 booked in thursday for service and check of every thing then SRR friday with ryan... place your bets on HP figure.... lol Link to comment Share on other sites More sharing options...
L33 Posted February 26, 2010 Author Share Posted February 26, 2010 Just sorting the gear box sump leak and there is a gasket on??? Split in 3 places and squashed tho and 2 colours of sealant the mechanic doin it isn't happy, but because now its apart its to late to get a gasket so goin to have to seal it! Have some wynns black gasket maker that was like 20 quid so I hope that will be ok and your right they don't need a gasket... Link to comment Share on other sites More sharing options...
L33 Posted February 26, 2010 Author Share Posted February 26, 2010 Also discovered while on the ramp the lsd I bought isn't a lsd!!!! Grrrrr Link to comment Share on other sites More sharing options...
JamieP Posted February 26, 2010 Share Posted February 26, 2010 Mate get rid of the silicon pipe on the breather, silicon is no good for oil vapour and that pipe is far to small. Link to comment Share on other sites More sharing options...
tooquicktostop Posted February 26, 2010 Share Posted February 26, 2010 Starting to sound like my old single car, really understand your pain mate Link to comment Share on other sites More sharing options...
L33 Posted February 26, 2010 Author Share Posted February 26, 2010 well i sorted the leaking gear box sump today was a bit of a horror seeing the mess of it when i took it off i found a gasket which looks like it had been reused a few times and then 2 colours of sealant from previous times its been apart so wud explain the leak so i sorted that out today, cost me 50 in all, 20 for the sealant and 30 for ramp hire time! 50 i shudnt of had to spend!! was interested to see what the turbo looked like with out the induction so whipped that off quickly but on the positive today i drove to a dvla office and had my number plate assigned to the car and i fitted a TRD half carbon spoiler Link to comment Share on other sites More sharing options...
wile e coyote Posted February 27, 2010 Share Posted February 27, 2010 Looking good mate What gearbox oil did you use to top up or did you not need any Link to comment Share on other sites More sharing options...
L33 Posted February 27, 2010 Author Share Posted February 27, 2010 (edited) Well nornal boxes use t2, done a search on here for the boostlogic and some one said t4, the only stuff I could get hold of which is the same apparently was TDX from halfords but can't remember who makes it but its drivin fine! I didn't top up I changed it completly so its not mixing as I had no idea what was in there looking at the state of the gasket don't think some one cared any way Edited February 27, 2010 by L33 (see edit history) Link to comment Share on other sites More sharing options...
SupraHuman Posted February 27, 2010 Share Posted February 27, 2010 I really hope it works out for you this time Lee.The season is upon us soon..... Link to comment Share on other sites More sharing options...
L33 Posted February 27, 2010 Author Share Posted February 27, 2010 Cheers mate I hope it does too had my fair share of bad luck don't you think? Lol Little bit annoyed my diff I bought from keron wasn't a lsd as told when I bought it can see it being another case of not being able to prove it so I can't be bothered with the headake again! I really need to clean it but I can't find any of my polish its only been a year ha ha seeing how good jamie cleaned his car do u recon if I slip him a 5er.... I will change those breather hoses jame but can't afford to just yet having had to finish paying labour, tax, insurance and the tonnes of fuel! Really could do with some new tyres as its rolling on budgets from ages ago!! I'm tryin to save hard again Link to comment Share on other sites More sharing options...
SupraHuman Posted February 27, 2010 Share Posted February 27, 2010 I am pretty sure Keron will make it right by You. Link to comment Share on other sites More sharing options...
dude Posted February 27, 2010 Share Posted February 27, 2010 Cheers mate I hope it does too had my fair share of bad luck don't you think? Lol Little bit annoyed my diff I bought from keron wasn't a lsd as told when I bought it can see it being another case of not being able to prove it so I can't be bothered with the headake again! I really need to clean it but I can't find any of my polish its only been a year ha ha seeing how good jamie cleaned his car do u recon if I slip him a 5er.... I will change those breather hoses jame but can't afford to just yet having had to finish paying labour, tax, insurance and the tonnes of fuel! Really could do with some new tyres as its rolling on budgets from ages ago!! I'm tryin to save hard again How do you know its not an LSD dude??? Link to comment Share on other sites More sharing options...
L33 Posted February 27, 2010 Author Share Posted February 27, 2010 Yea he was a nice bloke but I can picture the senario...keron will say he sent one, garage will say they fitted what they had delivered....stale mate? Link to comment Share on other sites More sharing options...
dude Posted February 27, 2010 Share Posted February 27, 2010 It prob will be a torsen if it came from Keron. How have you tested it. Link to comment Share on other sites More sharing options...
