single build almost done with pics :)
L33
not a clue....pretty stumped to be honest, like i said you can clearly see the 2 sensors, and if one was faulty then it wouldnt show a reading not show a simular one?
i havent pulled the gauges out yet or disconnected from the defi control box yet like i said one is in oil temp and one in water temp but that shudnt matter?!
  • Replies 331
Posted Images
well ive found the problem and sods law it only dripped a few times when on the ramp even tho we left it running, reved a bit and then cooled down but we didnt need the drip to see what the problem was
the gearbox sump gasket appears to be perished and a little bit of sealer seems to be flaking off! around the fixings the gasket is sticking out and seems like its falling apart. can push it with you finger and its spongy and small bubbles of oil are coming out
will get hold of toyota and order a new gasket so i can change that. the toyota garage is next door to my office which is handy stil a nusiance having to do this and cost more money
They should not have a gasket on at all dude, the gearbox sumps are silocone sealed from the factory
yea and that stuff aint cheap so i will reuse :)
the stuff my family friend mechanic is getting said its about 20 quid
Make sure both surfaces are nice and clean and do NOT put loads on, it will squish into the sump and can block filters etc.
the pics dont make the turbo look as big as it actually is!
and a bit of a update on the breather system, the left side of the rocker cover goes into the catch can and the right side goes throught a non return valve and then into the intake on the right which apparently is fine even tho its silicone
Just sorting the gear box sump leak and there is a gasket on??? Split in 3 places and squashed tho and 2 colours of sealant :( the mechanic doin it isn't happy, but because now its apart its to late to get a gasket so goin to have to seal it! Have some wynns black gasket maker that was like 20 quid so I hope that will be ok and your right they don't need a gasket...
well i sorted the leaking gear box sump today was a bit of a horror seeing the mess of it
when i took it off i found a gasket which looks like it had been reused a few times and then 2 colours of sealant from previous times its been apart so wud explain the leak :blink:
so i sorted that out today, cost me 50 in all, 20 for the sealant and 30 for ramp hire time! 50 i shudnt of had to spend!!
was interested to see what the turbo looked like with out the induction so whipped that off quickly :)
but on the positive today i drove to a dvla office and had my number plate assigned to the car and i fitted a TRD half carbon spoiler :)
Well nornal boxes use t2, done a search on here for the boostlogic and some one said t4, the only stuff I could get hold of which is the same apparently was TDX from halfords but can't remember who makes it but its drivin fine! I didn't top up I changed it completly so its not mixing as I had no idea what was in there looking at the state of the gasket don't think some one cared any way
Edited by L33 (see edit history)
Cheers mate I hope it does too had my fair share of bad luck don't you think? Lol
Little bit annoyed my diff I bought from keron wasn't a lsd as told when I bought it can see it being another case of not being able to prove it so I can't be bothered with the headake again!
I really need to clean it but I can't find any of my polish :( its only been a year ha ha seeing how good jamie cleaned his car do u recon if I slip him a 5er....
I will change those breather hoses jame but can't afford to just yet having had to finish paying labour, tax, insurance and the tonnes of fuel! Really could do with some new tyres as its rolling on budgets from ages ago!! I'm tryin to save hard again
How do you know its not an LSD dude???
