single build almost done with pics :)
L33
just a couple of pics from my gt4088, and full engine rebuild-build, obviosly not quite finished yet, and that heat shield is just a example, it is going to be bigger!
will post my full mod list tomo but the spec is pretty large, 15k large :)
to say im excited is a understatement!
should see her back soon, i cant wait, hoping for 600bhp!! :eyebrows:
big thanks to all those who have helped me along the way..
toyota gt for the work, whifbitz for loads of parts, heckler for sorting my gauges out, shane for supplying me with a lot of stuff and every one else thats helped, big thanks!
  • Replies 331
Posted Images
from memory...
GT4088 single turbo
boost logic auto box
3800 high stall torque converter
25 row transmission oil cooler with spal fan
full uk brake set up front and rear
stainless brake lines
hks 264 cams
greddy emanage ultimate ecu
wiseco forged pistons
sard 800cc fuel injectors
LSD
hks fuel cut defencer
hks ssqv (dump valve)
moddified fuel rail for twin feed
2x walbro fuel pumps
hks advanced timing pullys
gates racing cam belt
new toyota oil pump
new toyota water pump
all new engine bearings
all new engine gaskets
ARP head stud kit
polished rad pipe
polished intake manifold
3 core front mount intercooler
44mm tial waste gate
aeromotive fuel pressure regulator
blitz boost controller
custom intercooler pipes
custom down pipe
3 inch blits second decat pipe
screamer pipe
aem air to fuel ratio gauge
defi link boost, 2x oil temp, oil pressure and egt gauge
caron 3 gauge pod in glove box
2 gauge door pillar pod
bonnet gas struts
will go over my list tomo and see if there is any thing i have missed off :)
no comments in over a hour :( been dying to show ppl :(
Sorry ... have been outside with the children :p
Impressive spec list ;)
Are you confident the gearbox will be up the job for the 4088? What boost are you planning to run?
Luc
planning to run 1.5 bar max i think ? ryan g is hopefully going to mo to do a soft map to start running it in!
i recon the box will be ok thats y ive gone for such a big high stall, hoping the cooler and fan will do the job if not i will stick another in! have a gauge to keep a eye on it!
I would remove that silicone elbow from the compressor if I were you.Get a metal elbow welded on as I have seen a few of those elbows near the manifold getting too hot and failing.
Looking good by the way.
i will ring and mention the elbow thing tomo!
well i was hoping it would be back next week but it appears yet another problem has come up, my 18 inch wheels dont fit with the uk brake set up?
should i fit spacers? i really cant afford a new set of wheels? if so where can i get them from?
i will try and break it down, this will also help people planning a single build them selves...
i bought a nackered engined single turbo supra that i used..
gt4088 turbo, LSD, twin fuel pumps, 3 core fmic, 44mm tial waste gate, aeromotive fuel pressure regulator, boost controller, custom down pipe, screamer pipe, aem air to fuel ratio gauge £4500
then ive bought..
boost logic auto box £1500
3800 high stall £700
hks 264 cams, greddy emanage ultimate and wiring harnesses £1500
wiseco forged pistons £500
sard 800cc fuel injectors £500
hks ssqv £200
polished rad pipe £55
polished intake manifold £100
modify standard fuel rail to take twin feeds to replace tacky ebay jobby £80
25 row gear box rad, gates cam belt, hks pullys, oil pump, water pump and hks FCD £1000
full engine bearing kit, ARP head stud kit, full engine gaskets £560
defi control box, boost, oil temp, oil pressure and glove box carbon pod £780
defi egt gauge £150
second defi oil temp gauge £200
gear box rad fan £130
gas bonnet struts, 2 pod door pillar pod £120
full uk brake set up and stainless hoses £1422
3 inch blitz 2nd decat, coil pack clips £180
and a private plate :) £300
well that comes to £14447 :) lol and spent about 1k on bits of labour, boring out block for bigger pistons, putting LSD from the supra i bought to mine
stil have rest of labour to pay and mapping but that will come just under 4k i expect
I get that too, there seems to be a very lukewarm response to anything you post on this forum these days. You used to get lots of responses very quickly moons ago :(
I dunno if this is this forum in particular, or a general early disinterest in forum culture across the internet. I dont spend enough time on other owners forums to see if the same thing happens over there...
Great spec list, doesn't look like 15k though.... needs bling :D
believe me i would love bling BUT its not a essential, wanted to make sure i could afford every thing first before i go fancy
gives me some thing to do over winter too! :D
ally elbow being welded on now :)
