L33 Posted July 22, 2009 Share Posted July 22, 2009 just a couple of pics from my gt4088, and full engine rebuild-build, obviosly not quite finished yet, and that heat shield is just a example, it is going to be bigger! will post my full mod list tomo but the spec is pretty large, 15k large to say im excited is a understatement! should see her back soon, i cant wait, hoping for 600bhp!! big thanks to all those who have helped me along the way.. toyota gt for the work, whifbitz for loads of parts, heckler for sorting my gauges out, shane for supplying me with a lot of stuff and every one else thats helped, big thanks! Quote Link to comment Share on other sites More sharing options...
Luxluc Posted July 22, 2009 Share Posted July 22, 2009 Looks very nice ... come up with that spec list Quote Link to comment Share on other sites More sharing options...
L33 Posted July 22, 2009 Author Share Posted July 22, 2009 no comments in over a hour been dying to show ppl Quote Link to comment Share on other sites More sharing options...
L33 Posted July 22, 2009 Author Share Posted July 22, 2009 yay a comment lol! i will when i get home tomo as i have every thing wrote down Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted July 22, 2009 Share Posted July 22, 2009 well done dude, looking forward to seeing it finished Quote Link to comment Share on other sites More sharing options...
L33 Posted July 22, 2009 Author Share Posted July 22, 2009 from memory... GT4088 single turbo boost logic auto box 3800 high stall torque converter 25 row transmission oil cooler with spal fan full uk brake set up front and rear stainless brake lines hks 264 cams greddy emanage ultimate ecu wiseco forged pistons sard 800cc fuel injectors LSD hks fuel cut defencer hks ssqv (dump valve) moddified fuel rail for twin feed 2x walbro fuel pumps hks advanced timing pullys gates racing cam belt new toyota oil pump new toyota water pump all new engine bearings all new engine gaskets ARP head stud kit polished rad pipe polished intake manifold 3 core front mount intercooler 44mm tial waste gate aeromotive fuel pressure regulator blitz boost controller custom intercooler pipes custom down pipe 3 inch blits second decat pipe screamer pipe aem air to fuel ratio gauge defi link boost, 2x oil temp, oil pressure and egt gauge caron 3 gauge pod in glove box 2 gauge door pillar pod bonnet gas struts will go over my list tomo and see if there is any thing i have missed off Quote Link to comment Share on other sites More sharing options...
lockys96 Posted July 22, 2009 Share Posted July 22, 2009 your exhaust is very weird Quote Link to comment Share on other sites More sharing options...
L33 Posted July 22, 2009 Author Share Posted July 22, 2009 whys that? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted July 22, 2009 Share Posted July 22, 2009 no comments in over a hour been dying to show ppl Sorry ... have been outside with the children Impressive spec list Are you confident the gearbox will be up the job for the 4088? What boost are you planning to run? Luc Quote Link to comment Share on other sites More sharing options...
L33 Posted July 22, 2009 Author Share Posted July 22, 2009 planning to run 1.5 bar max i think ? ryan g is hopefully going to mo to do a soft map to start running it in! i recon the box will be ok thats y ive gone for such a big high stall, hoping the cooler and fan will do the job if not i will stick another in! have a gauge to keep a eye on it! Quote Link to comment Share on other sites More sharing options...
Luxluc Posted July 22, 2009 Share Posted July 22, 2009 1.5 bar on the 4088 should give you the power you're looking for. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 22, 2009 Share Posted July 22, 2009 I would remove that silicone elbow from the compressor if I were you.Get a metal elbow welded on as I have seen a few of those elbows near the manifold getting too hot and failing. Looking good by the way. Quote Link to comment Share on other sites More sharing options...
matt k Posted July 22, 2009 Share Posted July 22, 2009 I would remove that silicone elbow from the compressor if I were you.Get a metal elbow welded on as I have seen a few of those elbows near the manifold getting too hot and failing. Looking good by the way. Quote Link to comment Share on other sites More sharing options...
edge Posted July 22, 2009 Share Posted July 22, 2009 Bet your excited! Quote Link to comment Share on other sites More sharing options...
rob wild Posted July 22, 2009 Share Posted July 22, 2009 Looks good nice spec list! Some money spent there when are you planning to get it on the road? Quote Link to comment Share on other sites More sharing options...
L33 Posted July 22, 2009 Author Share Posted July 22, 2009 i will ring and mention the elbow thing tomo! well i was hoping it would be back next week but it appears yet another problem has come up, my 18 inch wheels dont fit with the uk brake set up? should i fit spacers? i really cant afford a new set of wheels? if so where can i get them from? Quote Link to comment Share on other sites More sharing options...
lockys96 Posted July 23, 2009 Share Posted July 23, 2009 get a set of stock uk wheels Quote Link to comment Share on other sites More sharing options...
Scott Posted July 23, 2009 Share Posted July 23, 2009 Great spec list, doesn't look like 15k though.... needs bling Quote Link to comment Share on other sites More sharing options...
L33 Posted July 23, 2009 Author Share Posted July 23, 2009 get a set of stock uk wheels ive sourced a set of spacers but 125 a pair! cant loose my chromes!!! Quote Link to comment Share on other sites More sharing options...
L33 Posted July 23, 2009 Author Share Posted July 23, 2009 i will try and break it down, this will also help people planning a single build them selves... i bought a nackered engined single turbo supra that i used.. gt4088 turbo, LSD, twin fuel pumps, 3 core fmic, 44mm tial waste gate, aeromotive fuel pressure regulator, boost controller, custom down pipe, screamer pipe, aem air to fuel ratio gauge £4500 then ive bought.. boost logic auto box £1500 3800 high stall £700 hks 264 cams, greddy emanage ultimate and wiring harnesses £1500 wiseco forged pistons £500 sard 800cc fuel injectors £500 hks ssqv £200 polished rad pipe £55 polished intake manifold £100 modify standard fuel rail to take twin feeds to replace tacky ebay jobby £80 25 row gear box rad, gates cam belt, hks pullys, oil pump, water pump and hks FCD £1000 full engine bearing kit, ARP head stud kit, full engine gaskets £560 defi control box, boost, oil temp, oil pressure and glove box carbon pod £780 defi egt gauge £150 second defi oil temp gauge £200 gear box rad fan £130 gas bonnet struts, 2 pod door pillar pod £120 full uk brake set up and stainless hoses £1422 3 inch blitz 2nd decat, coil pack clips £180 and a private plate £300 well that comes to £14447 lol and spent about 1k on bits of labour, boring out block for bigger pistons, putting LSD from the supra i bought to mine stil have rest of labour to pay and mapping but that will come just under 4k i expect Quote Link to comment Share on other sites More sharing options...
L33 Posted July 23, 2009 Author Share Posted July 23, 2009 as you can see i got a few baragins, so if i had to buy all that new it would of cost a lot more, most pleased with the defi stuff i got from shane, saved me a wedge! Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 23, 2009 Share Posted July 23, 2009 no comments in over a hour been dying to show ppl I get that too, there seems to be a very lukewarm response to anything you post on this forum these days. You used to get lots of responses very quickly moons ago I dunno if this is this forum in particular, or a general early disinterest in forum culture across the internet. I dont spend enough time on other owners forums to see if the same thing happens over there... Quote Link to comment Share on other sites More sharing options...
L33 Posted July 23, 2009 Author Share Posted July 23, 2009 it dont matter, guess if people dont really know u, they wont really look at topics u start!? Quote Link to comment Share on other sites More sharing options...
L33 Posted July 23, 2009 Author Share Posted July 23, 2009 Great spec list, doesn't look like 15k though.... needs bling believe me i would love bling BUT its not a essential, wanted to make sure i could afford every thing first before i go fancy gives me some thing to do over winter too! Quote Link to comment Share on other sites More sharing options...
L33 Posted July 23, 2009 Author Share Posted July 23, 2009 I would remove that silicone elbow from the compressor if I were you.Get a metal elbow welded on as I have seen a few of those elbows near the manifold getting too hot and failing. Looking good by the way. ally elbow being welded on now Quote Link to comment Share on other sites More sharing options...
