lethallee77 Posted July 22, 2009 Share Posted July 22, 2009 Hi guys after being a member for ages I finally got round to getting a soop yesterday:) but the clutch is starting to slip I was told that it might be because the hydrolic clutch is set at the wrong point if that makes sence is this true or is it a new clutch? sorry if it seems a silly question. Quote Link to comment Share on other sites More sharing options...
Mariusz Posted July 22, 2009 Share Posted July 22, 2009 Has it started slipping in the higher gears ? Quote Link to comment Share on other sites More sharing options...
lethallee77 Posted July 22, 2009 Author Share Posted July 22, 2009 yes its seems to be mainly in the high gears 1 and 2 seem ok Quote Link to comment Share on other sites More sharing options...
lethallee77 Posted July 22, 2009 Author Share Posted July 22, 2009 there also seems to be a clunk just before it slots into gear coming from the back but when the engine is off it does not make a sound is this related to the clutch? Quote Link to comment Share on other sites More sharing options...
supra dan Posted July 22, 2009 Share Posted July 22, 2009 sounds very much like you need a new clutch Quote Link to comment Share on other sites More sharing options...
lethallee77 Posted July 22, 2009 Author Share Posted July 22, 2009 new clutch it is then, what about the clunk, sounds like it's from the diff area people have said that the 6 speed is clonky but it's difficult to engage when the engine is running before it engages it clunks when the engine is not running its really smooth does slots straight in Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 22, 2009 Share Posted July 22, 2009 The 'clunk' is quite common on the 6 speed box, and it's also known for being fairly 'agricultural'. Get the clutch changed by a Supra specialist garage and get them to tell you whether your gearbox feels right or not. Quote Link to comment Share on other sites More sharing options...
