Fitz Posted July 21, 2009 Share Posted July 21, 2009 Recently, I have noticed that every now and then 4 LED's from the rear brake light bar intermittently stop working. Usually before I start driving they will all work but after a few minutes of driving or so they will stop working. Is this a common thing and/or simple to fix like a loose wire. Or does the LED stripp need replacing. Cheers in advance! Cliff Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted July 21, 2009 Share Posted July 21, 2009 The more important question here, is how do you know they're not working when you're sitting in the car driving it ---------------------- To be more contructive though, yes, you'll need a new LED strip. I'd get one from a breakers. Or, you could do what I saw another supra owner do at a meet, and disconnect the ones that are working intermitantly, and mirror the pattern on the other side of the strip, so you have a strip with even gapped working LED's. I thought it looked quite smart, when I spoke to him about it, he said he did it because some of them were not working, so he bodged it to at least make it look good. Quote Link to comment Share on other sites More sharing options...
heckler Posted July 21, 2009 Share Posted July 21, 2009 The more important question here, is how do you know they're not working when you're sitting in the car driving it ---------------------- To be more contructive though, yes, you'll need a new LED strip. I'd get one from a breakers. Or, you could do what I saw another supra owner do at a meet, and disconnect the ones that are working intermitantly, and mirror the pattern on the other side of the strip, so you have a strip with even gapped working LED's. I thought it looked quite smart, when I spoke to him about it, he said he did it because some of them were not working, so he bodged it to at least make it look good. Or if you know what your doing, and have the parts - you can repair them Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted July 21, 2009 Share Posted July 21, 2009 Or if you know what your doing, and have the parts - you can repair them Dude, I've seen your work, no mere mortal should attempt such feats Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 Lol, I had a friend of mine, Nash (horny_devil) drive behind me for a bit and he told me after I think as your car is off the road still, you should give me yours Thanks Dan. Will try and hunt one down. Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 Or if you know what your doing, and have the parts - you can repair them What's that heckler, you have the parts and you know what you're doing so you can repair them for me What a nice guy Just Kiddin' Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted July 21, 2009 Share Posted July 21, 2009 I think as your car is off the road still, you should give me yours Not for much longer Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 Not for much longer I'm still waiting, she back from the body shop yet? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted July 21, 2009 Share Posted July 21, 2009 Out of interest, while you're here Heckler. How hard would it be to modify the rear LED strip, so that when you apply the brake, the LED strip progressivly lights up from the center, then when you release the brake, the strip progressively scrolls back to the center until they're all off? Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 Ooooh, Good Question Quote Link to comment Share on other sites More sharing options...
heckler Posted July 21, 2009 Share Posted July 21, 2009 Out of interest, while you're here Heckler. How hard would it be to modify the rear LED strip, so that when you apply the brake, the LED strip progressivly lights up from the center, then when you release the brake, the strip progressively scrolls back to the center until they're all off? bit of electrickery - fairly easy... Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 Would you like to use my car as a guinea pig trial? Quote Link to comment Share on other sites More sharing options...
heckler Posted July 21, 2009 Share Posted July 21, 2009 Would you like to use my car as a guinea pig trial? LOL... I'd only need the strip... would have to make PCB for it... Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 Just tell me where to send it Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted July 21, 2009 Share Posted July 21, 2009 Really? Care to give me an outline of the basics of whats involved.? Quote Link to comment Share on other sites More sharing options...
heckler Posted July 21, 2009 Share Posted July 21, 2009 Just tell me where to send it give me two weeks, as I'm away with work, for the er.. next two weeks! Quote Link to comment Share on other sites More sharing options...
Homer Posted July 21, 2009 Share Posted July 21, 2009 Isn't it normally a dry solder joint? Quote Link to comment Share on other sites More sharing options...
heckler Posted July 21, 2009 Share Posted July 21, 2009 Isn't it normally a dry solder joint? Yup... Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 give me two weeks, as I'm away with work, for the er.. next two weeks! Take your time. No rush. Are you planning on attending any meets this year Heckler? As I'd love to see your car in the 'flesh', so to speak. Quote Link to comment Share on other sites More sharing options...
heckler Posted July 21, 2009 Share Posted July 21, 2009 Take your time. No rush. Are you planning on attending any meets this year Heckler? As I'd love to see your car in the 'flesh', so to speak. Ace cafe... supra pod maybe... possibly... JAE... Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 You'll be at Ace Cafe tomorrow? Quote Link to comment Share on other sites More sharing options...
heckler Posted July 21, 2009 Share Posted July 21, 2009 You'll be at Ace Cafe tomorrow? yup. Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 21, 2009 Author Share Posted July 21, 2009 Great stuff, I'll try and find you amongst the crowd. See you tomorrow bud. Quote Link to comment Share on other sites More sharing options...
heckler Posted July 21, 2009 Share Posted July 21, 2009 Great stuff, I'll try and find you amongst the crowd. See you tomorrow bud. Quote Link to comment Share on other sites More sharing options...
Guest horny_devil Posted July 23, 2009 Share Posted July 23, 2009 The more important question here, is how do you know they're not working when you're sitting in the car driving it ---------------------- To be more contructive though, yes, you'll need a new LED strip. I'd get one from a breakers. Or, you could do what I saw another supra owner do at a meet, and disconnect the ones that are working intermitantly, and mirror the pattern on the other side of the strip, so you have a strip with even gapped working LED's. I thought it looked quite smart, when I spoke to him about it, he said he did it because some of them were not working, so he bodged it to at least make it look good. becaus i was driving behind him! Quote Link to comment Share on other sites More sharing options...
