jamesmark Posted July 20, 2009 Share Posted July 20, 2009 The other halfs father was merging 2 partictions into one a program called partiction magic by power quest. It stalled on 3% and stayed like this for 4-5 hours so he switched it off. Now he cannot access the data that is on the drive. All that appears is PQ files instead of ntfs (I think that is what he said) and they only appear using a program called Acronis. Both Acronis and partiction magic do not have a recovery option. Anyone know of how to recover the data as he does not want to scrub it due to quite a bit of data being on it. Quote Link to comment Share on other sites More sharing options...
Guest superdave Posted July 20, 2009 Share Posted July 20, 2009 I think as the saying goes, it's stuffed and beyond recovery. Re partitioning any drive with data on it is risky:( Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 20, 2009 Share Posted July 20, 2009 Try using Getdataback from Runtime software, it usually does a good job. Quote Link to comment Share on other sites More sharing options...
Dave17 Posted July 20, 2009 Share Posted July 20, 2009 Partition magic is usually extremely good, i've done hundreds of jobs with it with no problem...hope you can get it back Quote Link to comment Share on other sites More sharing options...
jamesmark Posted July 20, 2009 Author Share Posted July 20, 2009 Try using Getdataback from Runtime software, it usually does a good job. Going to try this, see how he gets on. Quote Link to comment Share on other sites More sharing options...
MaveriK Posted July 21, 2009 Share Posted July 21, 2009 Recovermyfiles is cracking, tested it by formating and installing windows 3 times. Got back 65% of the old data. Worth noting that the "recovery" must be done on another machine with the old drive slaved or second mastered. If you try and do it from itself it will not work as well for obvious reasons. Good luck Quote Link to comment Share on other sites More sharing options...
