tomssupra Posted July 19, 2009 Share Posted July 19, 2009 Hi, I've just installed HID in the main beam, how do you get it in the low beam too? Thanks, Quote Link to comment Share on other sites More sharing options...
tony tt Posted July 19, 2009 Share Posted July 19, 2009 You will need a seperate set of hids on the low beams too would you not? I was thinking of hids for my main beam but decided against it because of the warm up time on them. Quote Link to comment Share on other sites More sharing options...
SteveR Posted July 19, 2009 Share Posted July 19, 2009 You will need a seperate set of hids on the low beams too would you not? I was thinking of hids for my main beam but decided against it because of the warm up time on them. Yep - main beam and dipped are 2 seperate sets of light. Even during their warm up time, the brightness still exceeds a normal bulb's output. Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 19, 2009 Share Posted July 19, 2009 yes and then once you have them in you end up with the onimous floating triangle that points into the sky and blinds the SHIT out of drivers coming toward you... needless to say i hate PnP kits Quote Link to comment Share on other sites More sharing options...
SteveR Posted July 19, 2009 Share Posted July 19, 2009 yes and then once you have them in you end up with the onimous floating triangle that points into the sky and blinds the $#@! out of drivers coming toward you... needless to say i hate PnP kits OR you can just aim them correctly. Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 19, 2009 Share Posted July 19, 2009 (edited) doesnt matter how you do it you will never match original equipment designed for the job PnP Retro using s2000 projectors Edited July 19, 2009 by Kirk (see edit history) Quote Link to comment Share on other sites More sharing options...
SteveR Posted July 19, 2009 Share Posted July 19, 2009 Not sure what I'm looking at there. I did my own PnP swapover on the dipped beam on my last Supra, current one has them fitted for dipped and main, and I won't ever go back to being without HIDs. The beam aim was the same before/after, the HIDs added more light, and a whiter (more useable) light and an even crsiper cutoff. Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 19, 2009 Share Posted July 19, 2009 well the top pic is the light output and beam pattern of a PnP kit and the bottom pic is of a s2000 projector retrofit output and cutoff and the PnP together.. This is the output of s2000 projecters on there own Im just loyal to retros what can i say Quote Link to comment Share on other sites More sharing options...
imi Posted July 19, 2009 Share Posted July 19, 2009 doesnt matter how you do it you will never match original equipment designed for the job PnP http://i164.photobucket.com/albums/u17/suprraaaaaa/hl_5.jpg Retro using s2000 projectors http://i164.photobucket.com/albums/u17/suprraaaaaa/hl_7.jpg wow, thats an amazing difference. Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 19, 2009 Share Posted July 19, 2009 hence why im loyal to only doing it that way, only limiting factor is trying to get some projecters on the cheap but definatly worth the extra effort for far better gains. You realy have to see them in person to realy appriciate them Quote Link to comment Share on other sites More sharing options...
Guest JDMDOM Posted July 24, 2009 Share Posted July 24, 2009 I have an HID kit on the regular healight and another kit on the fog light and as a right now i haven't need to use my hight beem! Quote Link to comment Share on other sites More sharing options...
