Turbos on diesels
far
Dudes on a larger engine diesel ( e60 bmw 530d) if the turbo is audiable to the point where you can hear a whistle with the window down could this be a failing turbo or would this be regarded as normal? Plugging it into a computers I am getting MAF sensor error - was thinking poss leak somewhere in one of the pipes?
I thought I would ask here as quite few of you have oil burners for your daily drivers
The 530 turbos do pack up. What mileage?
55k
I thought it would last much longer than that!
If it was a leak wouldnt I be loosing performance or experiencing flat spots?
Whats the best way to test for leaks?
sounds like a leak somewere as that will bring up maf errors. they do normally whistle (well the ones i have driven)
dude do they whistle fairly loudly? roughly the same loudness as a supra TT on spool?
my mates got a 535d, his whistle like a TT! arnt they set up on sort of sequential mode on 5 series?
on the 535d they are, the 530 has a single tubby
I just had it remapped (was whistling before too) - its touching 280 bhp now:d
I'm glad you are saying his whistle too - do we think I should just leave it or should I get it checked for leaks?
better be safe than sorry mate, if it worries you just get it checked! 280! crikey :blink:
ok, probably sound advice, im just not sure what to get the garage to check for in terms of leaks.
Yeah the remap is well within safe limits too, theres e60s that have done over 100k with the map
It does still seem a little slower than my supra did though :D
might be worth inspecting the turbo but if you have a split from the intake pipe to turbo it can give a whistle. and error codes.
ok cool, will try and locate it and check it out - I assume that this could add some more horses too if I plug a leak :D
Its a completely different culture on the 5 series forums, no one really seems to be tech savvy and most people tend to just point you to a dealer, have had more sense from you guys in 10 minutes than all day from over there! :(
Guest cathalferris
sounds more like a split or loose high pressure intake hose. a pinhole will whistle nice and loud.
Get someone to floor the throttle with the bonnet up, you may be able to locate the source of the air leak.
Look for signs of oil spray as the crank-case ventilation may be venting into the intake pre-turbo (by design), and this will aid leak location,
thanks dude - would I not feel a loss of power if that was the case?
Everything is under a big plastic cover in this car so will take it off and have a butchers tommorow
cheers
Remapped 535d here, 120k on the clock and counting at 600 miles a week.
Only issue I've had is rear tyres ;)
Well im seeing some oil leaks at the bottom of the engine on the undertray in a failry wide are - fairly minor (no puddles) but still there
Would the oil spray that is being described be appearing in this position? I have looked down from the top of the engine but couldnt locate the leak and everything appears nice and dry and clean all the way down to where I can see
Any help appreciated
