finally squeezed my gt4088 in
dr_jekyll
yea still stock running low boost . iv been na-t for over a year , im verry happy with it jus cooked the xs turbo so replaced with something higher quality, was a bit bigger than i thaught wen it arrived so i had to cut the two holed hanger off the side.
it stands me in good stead for wen i do the h/g and injectors and run more boost.
I had that removed on my last one as it's not needed when installed on the Supra engine.
excellent mate! definatly a worthy turbo and should forfill much higher powergains once boost is upped! only limiting factor then is the box :( cheap r154 in good nick can sort that out though :) what your running now? 6-7psi?
i have the 4 runner cap in thats as mutch room as im getting .
im currently running 6 psi on this turbo , i was running 8 on the old one , i will turn it up after a few hundred miles .
it is a nice drive on standard compression and low boost , feels verry sharp and responsive, but wen i have time and money i will be going up a notch with the box and boost
