Engine oil light faulty
dil
The yellow oil light in the right hand side row of warning lights has never worked in my car and as far as i knew it wasnt supposed to, noticed in Skywater's car that both his red one (which i guess is oil presure) and the yellow one ( which is oil level) are both working.
So I took the unit out of my car pluged it into his and wouldnt you know the yellow oil light came on, so i can rule out the unit/bulb be faulty, why doesnt it work on my car any ideas?
cheers:stupid:
Faulty Oil Switch/Sender.... EASY (expensive part ?)
Break in wiring/loom.... HARD (even MORE expensive - labour)
Not having a working oil light (level OR pressure) is one of the MOST
common reasons why cars are towed into our place with sha**ed
engines ! ! ! (*)
I'd get it checked/sorted ASAP !:(
I know the Soop is pretty reliable and we don't hear of too many
oil-pump problems.......BUT ! !
Mind you, even when they ARE working :-
"I saw the little red light on in Southampton, but I didn't know
what it was, so I ONLY drove back to Romford. Then it started
making a funny noise ?"
[actual words from one lady customer - Fiesta HCS so not too
dear ! just 2nd-hand crank and bearings - LUCKILY]
Fat S.
(* Timing Belt failure being number one ! ! ! )
No, sorry, haven't got to that one yet...:(
(sounded like I knew what I ws talking about before - sorry:music: )
Someone else will be on here later that DOES know where it
is / what it looks like.
I may 'troll' through the electrical pics on mkIV.com later and
see where it's located (if no0one says by then !)
YES, always screws in engine (block/head/ or oil-pump housing etc):thumbs:
Fat S.
[once found it should be easy to test - pull off wire, when
earthed on engine should light as-if switch is tripped.....
OR, it's earthed until the switch is tripped = ? ?:conf: ]
Another pic, this time wiring pic of warning lights.
Try clicking on link below and tell me if it works ?
Click here to visit the album on imira.com.
The LEVEL sensor = the left end is the 'float' in the sump
(IN the oil!), the right end is the 'switch' and will be on the
outside of the block (poking THROUGH the side - left side by looks
of it ?) it's a simple on/off when the float drops below a certain
level.
Fat S.
sorry Dil ! ?
don't know what happened there, the pic was 'gobble-de-gook' ?
I've just re-up-loaded it - try the link again...
(just tried it - seems OK now ?)
[ps. today I actually LOOKED at my warning lights..... YES
Orange LEVEL Light, and, Red PRESSURE Light ]
Fat S.
Nice one Martin,
That proves it's THERE...
Funny diagram though, it's like a micro-fiche, but, it doesn't
'line-up' each piece with where it goes ? ! ?
Somewhere on the Near-Side of the block (near the oil filter housing ?)
I'll have a look when I'm next under 'me bonnet.
GO FOR IT DIL . . . . .
