JohnH Posted July 16, 2009 Share Posted July 16, 2009 After i went for a run in the rain and unfortunately hit a puddle i couldnt see I got a fault and It seems i have a water temp/sensor circuit error but im unsure how to go about falt finding and getting a solution to my problem anyone have an idea's? Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 16, 2009 Share Posted July 16, 2009 some info from the manual Quote Link to comment Share on other sites More sharing options...
JohnH Posted July 16, 2009 Author Share Posted July 16, 2009 wicked, cheers bud i'll give a couple of the tests a try Quote Link to comment Share on other sites More sharing options...
JohnH Posted July 17, 2009 Author Share Posted July 17, 2009 Sorted, I couldn't see it last night because it was dark but one of the wires had come off the plug near the temp sensor, they are horribly brittle so going to change them today Quote Link to comment Share on other sites More sharing options...
azam Posted April 23, 2021 Share Posted April 23, 2021 Hi All, i need support with this, My supra was parked up for a few months over the winter, when its warming up it the engine light comes on and the handbrake lamp and runs like is dying. I read the codes and come back with 22 and 41. I checked the voltage of the sensor harness and showing as 4.8v to the ecu, the resistance is 2.83Kohms, which seems correct to the above. I have also checked the wires and the 1 pin is intact and the 2x pins are intact. I also checked other wiring around the engine bay and can't seem to find a fault. any advise would be appreciated, i have been trying to sort this for a while. Before parking the car up it was fine. Quote Link to comment Share on other sites More sharing options...
