keancy Posted July 16, 2009 Share Posted July 16, 2009 Last night my Hubby ran a Windows update and then shut down his PC. When he put it on this morning his Keyboard has disappeared and won't work at all. When he checked the Devices and isn't recognising a keyboard at all. His Mouse works fine and the PC boots normally into Windows. He also tried my Keyboard and the same thing happened. Both our Keyboards are not USB but the Pin Connectors. Anyone else having this problem and does anyone know what has happened?? I ran the same update on my PC last night but as I am at work I haven't yet been able to check if my PC still works or not. I did run the very same update on my Works PC before I went home last night and it is working perfectly fine but this keyboard here is a USB Connector one. Have borrowed a USB Keyboard from our IT department to try later today but any advise in the meantime would be appreciated. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 16, 2009 Share Posted July 16, 2009 I think you're doing the right things (i.e. try a USB keyboard). It's an unusual problem you have. The problem must be either that XP itself has lost its keyboard driver (unlikely), or there's a physical problem with the keyboard connector on your PC (even more unlikely!). If you boot into any non-windows environment (e.g. the BIOS, a DOS floppy disk, an XP installation CD, etc) you can see if the computer lets you type anything using the PS/2 (i.e. the old style of connector) keyboard. If it does, it proves the keyboard and connector are all OK and that the problem must be within XP itself. I suspect you may need to re-install the keyboard driver. An XP installation CD may allow you to do that, but I'm not sure off the top of my head. Quote Link to comment Share on other sites More sharing options...
DamanC Posted July 16, 2009 Share Posted July 16, 2009 You want the easiest solution? *hates to say it* Use a restore point. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 16, 2009 Share Posted July 16, 2009 D'oh! I keep forgetting about restore points! Quote Link to comment Share on other sites More sharing options...
keancy Posted July 16, 2009 Author Share Posted July 16, 2009 Thanks Guys will get Hubby to try those Options. Quote Link to comment Share on other sites More sharing options...
Shizzle Posted July 16, 2009 Share Posted July 16, 2009 edit: my advice has already been posted haha! Quote Link to comment Share on other sites More sharing options...
