What do you think of my induction setup?
hadyn
I do know the stock air box is better for performance, I just wanted to try something different to keep me interested :) I also removed the BOV too.
Car ran 13.3s with stock intake pipe and Blitz sus, so I'm wondering if this will make any difference? I have been blowing the intercooler to plenum hose off since I did this mod...
It's positioned perfectly for the fan to blow hot air onto the filter.
Hardly ideal, but couldn't you get a silicon or metal section made up to bring the filter forward 5-6 inches, it'll allow you to make a sheild to cover the rest of the side and back of the filter.
The short pipe, in some way makes the heat shield a bit useless, due to it being closer to the engine and not using the shield 100%, you could make it more efficient, ideally the pipe needs to be longer and an additional source of cold air from maybe where the SMIC would sit.
I would personaly revert back to the stock airbox as said above. Looks good mate but stock box will be better as this will suck alot of heat in from the engine bay i would imagine.
I know all about the pros of the stock airbox, I'm not a n00b :)
I just wanted to have a bit of fun. I'm keeping the outside of the car looking totally stock and just want to bling up my engine bay a bit.
Its all good fun.
Looks much better with the pipework extended.
I would suggest you have a UK spec chrome air intake pipe as it was way too short and brought the filter to close to the turbos.
But your use of silicon hose seems to have resolved that.
Are you still SMIC or FMIC btw?
SMIC - I ironically choose to keep the SMIC for the peformance benefits. Tell a lie, I cant be bothered to remove it to fit an FMIC!
I have a Miami GT SMIC that I fitted 3 odd years ago and its great :)
whats it like without the BOV, or do you have another somewhere
No BOV in the system now whatsoever.
Makes no difference to performance and basically sounds like the HKS SSQV on the 1st turbo. This is probably due to the HKS being wound in pretty tight and that the air is coming out of the Blitz sus creating the pssscht sound.
if it was FMIC you can cut underneath the ait filter and channel cool air in that way, but thats not an option with the SMIC.
