1994 N/A AC cold in morning but hot as hell in afternoon~
Guest OkinawaSupra
Guest OkinawaSupra
:( so I have charged the system and it gives off cold ac in the AM or when it feels like it really.. can hear the compressor turn on and then it turns off by itself. The AC light stays on but the compressor turns on and off. when the AC is cold one of the ac lines is really ICE cold. When the AC isn;t working both lines under the hood are hot as crap! Keep in mind when the Ac isn't working I mean its blowing Hot air.. depite the fact that the compressor is still spinning and that everything is still unchanged. Any ideas? is there suppose to be something going on with the glass viewer next to the High pressure inlet? I see no foam or liquid looks dry inthere. Thanks in advance!!
Guest OkinawaSupra
the line closest to the passengerside is cold when the ac works... but when it blows hot air both hardlines are warm... compressor still spinning is there a valve or accumulator somewhere that may be faulty. Seems like the ac fails when its really hot out
