exhaust
wop
As above, most aftermarket exhausts will be very loud on an NA, especially if decatted.
The one from Paul looks to be a great option for those wanting to keep the noise down. Other options are the track day systems from Tannabe.
cheers 4 the info scooter the last owner welded the back box section to the middle section and the middle box is now blowing out is a cat back from up at the engine to the back i dont like the loud saxo corsa wee boy sound cheers
The XS Power exhausts (they're actually made by another company) are certainly cheap enough and appear fairly well made (currently on eBay at £208 delivered), but almost everything I've ever read about them on here and elsewhere indicates that they are very loud...
well, they certainly gave a good rumble on idle and yes it is quite loud but its not really that bad.
I suppose everyone's opinion of 'loud' is different. :) The XS Power exhausts are certainly cheap enough and look the part - that is, if you don't mind a bit of noise and you have understanding neighbours. :D
