Meguiars
jazz1
I just bought the 3 step big bottles and loads cloths etc and after iv used these three bottles the forth final bottle i will use is the high tech wax that i also bough. Anybody know using these 4 products make any difference? anything else i should use? apart from gold eash shampoo?
I used them and yes they do, especially on black :)
wicked i used the high tech wax that gives a nice shine and helps with swirls but alot of people recommend the 3 step so just wanted to check if theres anymore i could use or are the four bottles i have enough to give me glass finish
You won't get a "glass" finish with that collection but it should look quite nice if done correctly and you don't look too close :)
:p lol i also just found a bottle of quick detailer should i use this as my 5th final detail?
Although what i found is that if you use the Meguiars clay bar an quik detailer you will get a lovely glass finish as i thought it was superb on my car and got rid of all the oxidation and swirl marks in the paint!!;)
I had the clay bar some where in the house cant find it, i might go and buy that im going to give it a 5 step detail tommorow
I generally go in the following manner
Initial super detail
Secondary initial super hyper detailer
Primary hyper quik detailer
Mid stage super mega detailer
Tertiary stage super hyper mega detailer
Quik detailer
Detailer
Detail.
wow that seems alot does it make a huge difference in shine?
To be honest i washed mine and then quik detailed it with the that and the clay bar and finished off with the little bottle of wax they put in there and i didnt need to do anything else althought maybe after a month put on a coat of tech wax to keep it going ;)
i generally go in the following manner
initial super detail
secondary initial super hyper detailer
primary hyper quik detailer
mid stage super mega detailer
tertiary stage super hyper mega detailer
quik detailer
detailer
detail.
:D
guess the 5 stages i have should be enough than:)
Quik detailer
Detailer
Detail.
:lol:
Quik detailer
Detailer
Detail.
No pre detail soak? No pre detail balm and smooth detail lotion?
Pfft!
