Guest vipprotuning Posted July 14, 2009 Share Posted July 14, 2009 hi, I´ve fitted an hks fcd and it doesn´t work at all and its screwed up the car, it goes with less power and i think its no good, or it was badly set up, i don´t know. The thing i´ve uninstalled the hks fcd and the car is running as bad as it was with the fcd connected. What can i do???? Quote Link to comment Share on other sites More sharing options...
legendswraith Posted July 20, 2009 Share Posted July 20, 2009 Define badly? Does it feel like you are at boost cut all the time? Have you reset the ECU to see if that cures the initial problems you have after the FCD removal? Did you use the right FCD for the application? Is it a non vvti or a vvti model. Auto or manual? Quote Link to comment Share on other sites More sharing options...
jacko Posted July 20, 2009 Share Posted July 20, 2009 Is the FCD on the correct setting? Quote Link to comment Share on other sites More sharing options...
jamesmark Posted July 20, 2009 Share Posted July 20, 2009 The first thing that went wrong is you fitted the HKS unit, they are not a good FCD and can be dangerous for the car as it removes fuel cut totally. iirc the HKS does not need setting? I may be wrong though. There is a fitting guide on http://www.mkiv.com that may confirm if it does or not. As above, more info re how the car is running. Have you checked to see what error codes are stored? That should be the first thing to check. error codes Quote Link to comment Share on other sites More sharing options...
legendswraith Posted July 20, 2009 Share Posted July 20, 2009 Depends on which one i think. The auto one i used was dip switches and i have seen a version with a potentiometer on it. Quote Link to comment Share on other sites More sharing options...
