MOT emissions faliure
supra dan
just had my mot, only thing it failed on was emissions. ive got both cats removed, but it passed last year no problem like this, so i just want to check that this is the problem.could someone tell me if this looks like a cat would solve the problem?
fast idle
CO level ;0.83% fail - 0.3
HC level ;80ppm pass
lambda ;1.02 pass
natural idle
CO level ; 0.64% fail
i had a 200sx with the cat removed,it failed so i refitted the cat and it still failed! turned out to be the lamda sensor. would changing the sensor work? any help appreciated
cleaning the lamba sensor is easy anyway so you may as well do that as well. Mine failed on emissions (with both cats in) so took lamba sensor off, cleaned it with petrol in end, put it back in and it passed, but i made sure the cats were cooking before i got to mot station. Cleaning the lamba sensor with presurised air is best way to do it! Search for thread by me of 'mot failure' or along those lines!
