Wez Posted July 13, 2009 Share Posted July 13, 2009 Hey All, I am looking at plumbing in a brake pressure sensor and wondered where best to place it on the braking system, my car still has ABS installed. Link to comment Share on other sites More sharing options...
Wez Posted July 13, 2009 Author Share Posted July 13, 2009 bump Link to comment Share on other sites More sharing options...
SteveR Posted July 13, 2009 Share Posted July 13, 2009 At long last! Will watch with interest. Link to comment Share on other sites More sharing options...
Wez Posted July 13, 2009 Author Share Posted July 13, 2009 Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 13, 2009 Share Posted July 13, 2009 By the M/cylinder, one in the front circuit, one in the back. I'd need to sit down and think just how the ABS would affect readings. Can you log it? Link to comment Share on other sites More sharing options...
Wez Posted July 13, 2009 Author Share Posted July 13, 2009 By the M/cylinder, one in the front circuit, one in the back. I'd need to sit down and think just how the ABS would affect readings. Can you log it? I was hoping I could do it with a single sensor as they are £150 each, they will be wired into a datalogger so yes logging will be possible. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 13, 2009 Share Posted July 13, 2009 You need two. It won't really tell you very much to be honest. You set bias to suit track and tyres, the pressure differential's pretty academic. Link to comment Share on other sites More sharing options...
Wez Posted July 13, 2009 Author Share Posted July 13, 2009 You need two. It won't really tell you very much to be honest. You set bias to suit track and tyres, the pressure differential's pretty academic. OK two it is then Link to comment Share on other sites More sharing options...
SteveR Posted July 13, 2009 Share Posted July 13, 2009 I can't be bothered to link to the Solaris forum thread where you talked about doing this - last year. Link to comment Share on other sites More sharing options...
Wez Posted July 13, 2009 Author Share Posted July 13, 2009 I can't be bothered to link to the Solaris forum thread where you talked about doing this - last year. I will get there, these things take time Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 13, 2009 Share Posted July 13, 2009 http://www.racecarsdirect.com/listing/25448/PI_Research_system_3c_datalogger.html Link to comment Share on other sites More sharing options...
Wez Posted July 13, 2009 Author Share Posted July 13, 2009 http://www.racecarsdirect.com/listing/25448/PI_Research_system_3c_datalogger.html Price looks good, if I didnt already have a dash etc I would prob go for that. Link to comment Share on other sites More sharing options...
SteveR Posted July 13, 2009 Share Posted July 13, 2009 I will get there, these things take time No worries. I don't mean to be rude. Where you go - with gadgety cool stuff the Solaris can have added to it - I hope to follow. Link to comment Share on other sites More sharing options...
Wez Posted July 14, 2009 Author Share Posted July 14, 2009 This is the sensor I am looking at, what would be the best way to install them? Description Manufactured by Bosch, this brake pressure sensor is specifically designed for measuring the high pressures in automotive braking systems. It is extremely robust and resistant to brake fluids, mineral oils, water and air. Technical Data Pressure range (bar) 250 (Mpa) (25) Offset accuracy (Uv) 2.0% Sensitivity accuracy at 5V In range 0...35 bar FSƒU of measured ≤0.7% In range 35...250 bar (value) ≤5.0% (of measured value) Power supply voltage Uv (V) 5 ±0.25 Power supply current Iv (mA) ≤20 Output current ID (uA...mA) -100...3 Output voltage (V) 0.5 - 4.5 Temperature range (°C) -40...+120 Overpressure max. Pmax (bar) 350 Burst pressure Pburst (bar) >500 Tightening torque Ma (Nm) 20 ±2 Pressure port thread M10 x 1mm pitch Overal length (mm) 55 Note: All data are typical values Design and function Pressure measurement results from the bending of a steel diaphragm on which are located polysilicon strain-guage elements. These are connected in the form of a Wheatstone bridge. This permits high signal utilisation and good temperature compensation. Part of the evaluation IC is applied for a diagnostic function which can detect the following potential defects: - Fracture of a bonding wire to the measuring cell. - Fracture anywhere on any of the signal lines. - Fracture of the bridge supply and ground. Following switch-on the sensor runs a self-test diagnostic function checking for correct calibration and functionality. During normal operation a diagnostic function checks for errors. If an error is detected, the signal output is switched to the voltage range >96% Uv. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 14, 2009 Share Posted July 14, 2009 Well, apart from very carefully I'd buy two T pieces and fit them near the MC in the hard lines. You'll need 4 end fittings and a flaring tool, and some Kunifer brake line as well. Link to comment Share on other sites More sharing options...
SteveR Posted July 14, 2009 Share Posted July 14, 2009 Wez, if Chris' instructions mean more to you than they do to me, please take 'how to' style photos when you follow them, ta. Stupid question: why not rig up a crude brake pedal position sensor? I know it's not going to be as accurate (e.g. is brake pedal position proportional to brake pressure?) but what does that exctra acuracy give you, Wez? Link to comment Share on other sites More sharing options...
Gordon F Posted July 14, 2009 Share Posted July 14, 2009 To get accurate front and rear brake pressures, wouldn't the sensors have to be fitted after the proportioning valve? Link to comment Share on other sites More sharing options...
Wez Posted July 14, 2009 Author Share Posted July 14, 2009 Does anyone have a HPC screen shot of the braking system? We could the look where would be best to tap these sensors. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 14, 2009 Share Posted July 14, 2009 To get accurate front and rear brake pressures, wouldn't the sensors have to be fitted after the proportioning valve? Good point, does the MKIV have one? Or does it rely on multi channel ABS for "proprtioning"? I know the UK spec has a more sophisticated ABS than the J-Spec. Ripping the ABS off altogether would simplify things. Fitting the Bosch Motorsport configurable ABS would be awesome, but probably bankrupting. Link to comment Share on other sites More sharing options...
TLicense Posted July 15, 2009 Share Posted July 15, 2009 Wes, I think what you're more interested in rather than the amount of pressure being applied to the discs, is how much force you're hitting the brake pedal with? If so then putting the sensors post ABS might be a bit misleading as I'm not sure how the ABS regulates the pressure? Imagine if you brake into a corner and the ABS kicks in, you're going to end up seeing fluctuating pressures which would have little to no correlation to pedal force. Chris, If Wes was to place a sensor between the master cylinder and the ABS pump, would that give a direct indication of pedal pressure? At this stage in his racing career I would imagine he's looking to get driving consistency? Of cource the ultimate set-up would be to monitor pedal pressure (or even position) as well as pressure at each caliper (although on each circuit should give very similar results). What do you guys recon? Link to comment Share on other sites More sharing options...
Wez Posted July 15, 2009 Author Share Posted July 15, 2009 Here are a couple of pics from the ABS unit and lines, not sure how I would get away with one sensor although it would be great if I could. Link to comment Share on other sites More sharing options...
Wez Posted December 16, 2009 Author Share Posted December 16, 2009 Digging up this thread as I am in process of ordering everything to fit the sensors, I decided that near the MC is the best place but without pulling the lines out does anyone know if the M10 x 1mm threads are inverted, concave or flat? I am planning to use a single -3 output bango fitting to the sensors with a -3 M10 x 1mm bango bolt out to a female -3 M10 x 1mm adapter but need to know the seat type. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 16, 2009 Share Posted December 16, 2009 I am 90% sure the M/C has inverted flare seats in it. They certainly are not flat! Just flare the pipe end to suit if using hard lines. The fitting will be the same on hard lines. Link to comment Share on other sites More sharing options...
Wez Posted December 16, 2009 Author Share Posted December 16, 2009 I am 90% sure the M/C has inverted flare seats in it. They certainly are not flat! Just flare the pipe end to suit if using hard lines. The fitting will be the same on hard lines. Where is the best place to get the hardline parts, I have been looking at getting the bits needed from speedflow. This is an inverted seat http://www.speedflowshop.co.uk/ekmps/shops/speedflow/images/231_cut_away_08.07.gif This is a concave seat http://www.speedflowshop.co.uk/ekmps/shops/speedflow/images/female_concave_metric.gif Link to comment Share on other sites More sharing options...
Wez Posted December 16, 2009 Author Share Posted December 16, 2009 Hadnt thought about the hardline option, I could cut the stock line back and fit a -3 fitting using a flaring tool, then run a new -3 line from the MC and sensor into a -3 T-Piece. How does that sound? Would this flaring tool be any good, they retail at approx £26 http://www.screwfix.com/sfd/i/cat/35/p1159535_x.jpg Link to comment Share on other sites More sharing options...
