L33 Posted July 13, 2009 Share Posted July 13, 2009 I've been in bigger turbo singles yes, and I haven't got on with the lag. I don't know, it does vary from spec to spec, but silly horse power is not useable. We'll see like you say but i'm pretty confident i'll stick it out. My box is built, similar to a boost logic. I'd never get on with a high stall though. such a different driving experiance. not keen easiest way to get over lag! ive got the 3800 on my gt4088! Link to comment Share on other sites More sharing options...
JamieP Posted July 13, 2009 Share Posted July 13, 2009 Nice one Matt, enjoy. easiest way to get over lag! ive got the 3800 on my gt4088! Are you driving yours now? Link to comment Share on other sites More sharing options...
L33 Posted July 13, 2009 Share Posted July 13, 2009 no but ive just gone on peoples word/experience Link to comment Share on other sites More sharing options...
vvteye Posted July 13, 2009 Share Posted July 13, 2009 well my experience is that the GT40 is a bit like sex at my age... it takes ages to get going but when it does, it's over in a flash. (Beats the classic car I had as that needed starting by hand ) Link to comment Share on other sites More sharing options...
L33 Posted July 13, 2009 Share Posted July 13, 2009 like i said thats y i was recommended fitting the high stall, reduces a lot of lag! Link to comment Share on other sites More sharing options...
vvteye Posted July 13, 2009 Share Posted July 13, 2009 Will it fit under my truss? Link to comment Share on other sites More sharing options...
dude Posted July 13, 2009 Share Posted July 13, 2009 easiest way to get over lag! ive got the 3800 on my gt4088! Hope you have fitted a lock up switch or it will get very hot on the motorway!!!!! Link to comment Share on other sites More sharing options...
L33 Posted July 13, 2009 Share Posted July 13, 2009 no i havent have a 25 row cooler and a high powered fan Link to comment Share on other sites More sharing options...
dude Posted July 13, 2009 Share Posted July 13, 2009 no i havent have a 25 row cooler and a high powered fan You need to fit a lock up switch trust me, that set up will not even start to cool the trans down with it slipping, which it will on the motorway, your mpg will drasticaly improve with a lock up as well!!!!! Link to comment Share on other sites More sharing options...
hodge Posted July 13, 2009 Share Posted July 13, 2009 Sorry for the hi-jack but what's a lock up switch. Link to comment Share on other sites More sharing options...
L33 Posted July 13, 2009 Share Posted July 13, 2009 stops the box dropping a gear with slight kick down say for over taking ive heard loads about this, some have them some dont, they just learn to control it with careful right foot. cant find where to get one from tho? Link to comment Share on other sites More sharing options...
jevansio Posted July 13, 2009 Share Posted July 13, 2009 Nice one Matt, be good to see you & your car when you're up this way Link to comment Share on other sites More sharing options...
tDR Posted July 13, 2009 Share Posted July 13, 2009 Agree with dude, you need a lock up switch fitted when running a hi stalled car on Mway journeys. It locks the TC 1:1 with the input shaft on the box rather than allowing it to slip, giving you direct drive and stopping the constant slipping you tend to get which just builds more and more heat... ultimately boiling your trans fluid and cooking the autobox. We used a relay on mine connected into the appropriate wire from the ECU loom hooked up to a switch on the dash - it just sends to ground when pressed. Pin 21 rings a bell in my head but do a search as I'm not certain, there's a thread describing what kind of relay to use and what pin to target. Don't go full load whilst driving in lock up mode as the mechanical linkage isn't particularly strong - just use it for cruising. I've run my PI 3,800 stall car on several long trips without issue but always using my lock up switch when Mway cruising. As per previous posts, I also have 3x trans rads to keep my fluid and BL box as cool as possible. Cheers, Brian. Link to comment Share on other sites More sharing options...
jon5698 Posted July 13, 2009 Share Posted July 13, 2009 Jurgens brother has just got a new set of dyna pack or dyno dynamics rollers at XO in gateshead which is quiet close to Durham, i am not sure if he has them installed yet though, you could ask Jurgen. Link to comment Share on other sites More sharing options...
Matt H Posted July 14, 2009 Author Share Posted July 14, 2009 no but ive just gone on peoples word/experience like i said thats y i was recommended fitting the high stall, reduces a lot of lag! You can't recommend something you have no experiance of! High Stalls arn't the best day to day driving experiance. It's a different ball game, there's a trade off for launching faster. well my experience is that the GT40 is a bit like sex at my age... it takes ages to get going but when it does, it's over in a flash. Jurgens brother has just got a new set of dyna pack or dyno dynamics rollers at XO in gateshead which is quiet close to Durham, i am not sure if he has them installed yet though, you could ask Jurgen. Cheers for that Link to comment Share on other sites More sharing options...
hodge Posted July 14, 2009 Share Posted July 14, 2009 save ya money n just remove the traction control n ya box goes daft anyway n wont change til you phsh hard on the throttle Link to comment Share on other sites More sharing options...
tDR Posted July 14, 2009 Share Posted July 14, 2009 save ya money n just remove the traction control n ya box goes daft anyway n wont change til you phsh hard on the throttle We're not talking about autobox change points or harshness, we're talking about torque convertor slip and how to avoid it on mway runs. Link to comment Share on other sites More sharing options...
hodge Posted July 15, 2009 Share Posted July 15, 2009 Sorry my bad LOL. That will teach me not to read the whole thing LOL. Link to comment Share on other sites More sharing options...
