strange sound from coils
Digital
When I turn on the ignition(not starting) the coils give a strange "electical" sound, which I can also hear through the exhaust manifold, as if the sparkplugs are continuous firing or something(haven't looked yet). When I disconnect the connectors from the coils the sound goes away more and more with each coil. After this, still with the ignition still on, when I put the connectors back on the sound is still gone.
Does somebody have a clue what is going on?
I just tested another igniter, problem still there.
Then just to be sure I pulled out a sparkplug, put the coil back on and put the sparkplug on ground. Turned the ignition back on(not starting) and the sound was there again, and the sparkplug fires!
So this is my problem, when I turn the igintion on all 6 sparkplugs are firing...anybody?
There was a simple alarm-system in the car, most wires where connected to some places under the steering wheel, I neatly disconnected the ones which where linked to OEM wires, and 2 wires where "interrupting" one OEM, I disconnected them and put the OEM back together. Could this have something to do with my problem with the sparkplugs?
Something is triggering the LT side of the coils, an alarm in the ignition circuit that had gone mad MIGHT do it, I'm not qualified to say, but I have a lot of trouble with alarms and none / bad starting. It would have to be effectively switching the ignition on a nd off very fast. RyanG on here might know?
Hmm, the sensors, that's something worth checking, but the engine which I put in now came off a good working car.
Does a JDM 1993 AT TT has something like a original "starting-disrupter"(don't know the English word for it)?
I feel like I correctly disconnected the alarm(cutting away linked wires and 1 reconnected, a patched everything neatly), but since this is the only thing that I've adjusted I would almost want to search the problem behind the steering wheel..
In general, could I (dis)connect something immproperly behind the steering wheel to create this problem?
IF it was the crank sensor triggering the coils then your fuel pump will also be running all the time when ignition is on. you should have a constant 12v feed to the coil packs and the negative is controlled via ignitor/ecu, check to see if you are getting a negative with the ignitor disconnected. it could be trapped wires sorting out somewere.
