Rebuild parts
RobSheffield
Ok, guess i best make a start.
Wanted in new/used and good condition, traders welcome
T71dbb
CP pistons (likely to need to hold off on these until i strip the block and check for ovality/bore wear)
Carrillo rods
ARP bolts
Full gasket kit
ACL bearings (again need to confirm sizing)
1000cc injectors
4" DP & MP
BL T4 manifold - new preferred to be ceramic coated.
  • 3 weeks later...
T71dbb
Carrillo rods
ARP bolts (L19 head bolts)
Full gasket kit
1000cc injectors
4" DP & MP
L19 head bolts !! you really dont need this, standard ARP are good enough
have you won the lottery mate :D, MVP might be a good call for some of your parts now the exchange rate has recovered a bit
Lol, yeah id seen they were strong so wanted to go with them!
Normal sized ARP will be fine :)
