hadyn Posted July 12, 2009 Share Posted July 12, 2009 Removed my HKS SSQV today and I have decided to run with no BOV, I used the following procedure and I just need to know its OK. Both outlets in the turbo pipes are blocked up and I've also blocked the top thin vacuum pipe with a screw - is this OK?? Secondly, I've got a Blitz SUS air filter on mine at the moment and running no BOV, I cant hear any chatter whilst moving, the only noise I can hear is a quiet zip pssscht just like a vent to atmosphere BOV????? Does that round right to you? Quote Link to comment Share on other sites More sharing options...
Scott Posted July 12, 2009 Share Posted July 12, 2009 Yup thats exactly what mine was like. As for the vacuum pipe, do you have a boost gauge? If so there might be a t-piece, you could take that out instead. Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 12, 2009 Author Share Posted July 12, 2009 Yep I'm running a boost gauge - are you saying I can block off the feed from the join to the boost gauge? Quote Link to comment Share on other sites More sharing options...
Scott Posted July 12, 2009 Share Posted July 12, 2009 Yep I'm running a boost gauge - are you saying I can block off the feed from the join to the boost gauge? No, you will have a t-piece splitting the vac line to the boost gauge and the BOV. Take out the t-piece and just leave the line going direct to the boost gauge. Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 23, 2009 Author Share Posted July 23, 2009 Just for reference heres a pic which shows the pipes that need bunging up with the BOV removed: Quote Link to comment Share on other sites More sharing options...
Scott Posted July 23, 2009 Share Posted July 23, 2009 Do you have a boost gauge? IF you do... Disconnect the one with the screw in it from the metal pipe Follow metal pipe to the rear of the engine and you will notice a vac line (i think this is connected to the manifold via a t-piece?) If your boost gauge is on the same T-Piece, remove the T-Piece and connect the boost gauge directly into the manifold. Bobs your auntie's cousin. Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted July 23, 2009 Share Posted July 23, 2009 Bobs your auntie's cousin. So not your uncle then? Don't do it it's a trap! Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 23, 2009 Author Share Posted July 23, 2009 Do you have a boost gauge? IF you do... Disconnect the one with the screw in it from the metal pipe Follow metal pipe to the rear of the engine and you will notice a vac line (i think this is connected to the manifold via a t-piece?) If your boost gauge is on the same T-Piece, remove the T-Piece and connect the boost gauge directly into the manifold. Bobs your auntie's cousin. Why would I want to do that, apart from removing the pipe with the screw in it? Quote Link to comment Share on other sites More sharing options...
Scott Posted July 23, 2009 Share Posted July 23, 2009 Fair enough then Sounds like a turbofit mod. Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 23, 2009 Author Share Posted July 23, 2009 Its a safe and sound bung, so all is good Quote Link to comment Share on other sites More sharing options...
Scott Posted July 23, 2009 Share Posted July 23, 2009 Long as your happy I thought you were looking for options lol, sorry. Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 23, 2009 Author Share Posted July 23, 2009 Well if you were a total perfectionist, you could also chop down the bunged hose on the right of the pic too. Quote Link to comment Share on other sites More sharing options...
Scott Posted July 23, 2009 Share Posted July 23, 2009 I made little aluminium bungs in work Trimmed the pipe right back to tidy it up. Been doing a lot of work in the engine bay though. Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 23, 2009 Author Share Posted July 23, 2009 You'll have to post up pics of your bay Scott Quote Link to comment Share on other sites More sharing options...
Scott Posted July 23, 2009 Share Posted July 23, 2009 Got it on my site bud, Linky This was it WIP http://www.scotster.pwp.blueyonder.co.uk/Supra/Rad%20Plate/DSCF1924.JPG Its now finished but i don't have any pics of it yet (up on blocks while i get the brakes done). Here is the "latest" pic i have, its distant but you can make out that everything is black and red lol. Just had the throttle body and inlet manifold to do at this point, its all done now. http://www.scotster.pwp.blueyonder.co.uk/Supra/Dat%20Inter%20Meets/IMG_0651.jpg Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 23, 2009 Author Share Posted July 23, 2009 Superb car and you've just gotta love that Arc induction box Scott Quote Link to comment Share on other sites More sharing options...
Scott Posted July 23, 2009 Share Posted July 23, 2009 Superb car and you've just gotta love that Arc induction box Scott Thanks bud. Bloody expensive bit of kit, and i can't really say its worth it, but there is nothing else like it IMO. I wanted it so had to bite the bullet. Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 23, 2009 Author Share Posted July 23, 2009 Have you still got that blue spark plug cover knocking about? Quote Link to comment Share on other sites More sharing options...
Scott Posted July 23, 2009 Share Posted July 23, 2009 Have you still got that blue spark plug cover knocking about? Na thats the one i painted black bud lol.... badly i may add. Need to sort that out at some point. Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 31, 2009 Author Share Posted July 31, 2009 Think I might go back to running with a BOV again after today I noticed some slight stumbling/hesitation at rev limit gear changes with O/D off on the autobox. I can only put this down to having no BOV and air still in the system? Quote Link to comment Share on other sites More sharing options...
Geo Posted July 31, 2009 Share Posted July 31, 2009 Sorry to Hijack your thread mate. But do you need a BOV, when running twins/single does it affect performance?? Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted August 1, 2009 Share Posted August 1, 2009 Sorry to Hijack your thread mate. But do you need a BOV, when running twins/single does it affect performance?? In short.....no Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 1, 2009 Author Share Posted August 1, 2009 I have no issues with my car running no bov at lower speeds. The hesitation I've experienced at high rpm gear changes has made me want to put a bov on, either stock or vent to atmosphere.. Quote Link to comment Share on other sites More sharing options...
