n boost Posted July 11, 2009 Share Posted July 11, 2009 My mrs punto had an oil leak from the sump of her car, so decided i would change the sump myself:( Now i have removed all bolts and the fecking sealer and the sump is loose and hanging but in can not get it out! If anyone knows the procedure please help and the car is a 2000 1.2 8 valve. I can not tell where the little basket is catching and is really peeing me off! Thanks in advance. p.s FIAT...failure in automotive technology. Quote Link to comment Share on other sites More sharing options...
absz Posted July 11, 2009 Share Posted July 11, 2009 not worked on fiats but it might be the oil pickup strainer, can you see the pipe when sump is lowered slightly if so you might be able to undo the bolts holding it on. have done this on other vehicles before. Quote Link to comment Share on other sites More sharing options...
RobD Posted July 11, 2009 Share Posted July 11, 2009 Have you took the little metal plate that sits at the bottom off the bell housing off and the crank pully? This makes it a lot easier to remove, it catches on the oil stainer be carefully not to break it! Quote Link to comment Share on other sites More sharing options...
n boost Posted July 12, 2009 Author Share Posted July 12, 2009 Ok guys, realised what i have not done! Checked on fiat forum and i need to remove bell housing cover,gearbox support bracket and the exhaust manifold!( stupid fiat design) Started taking the exhaust manifold off and yes 1 fecking rusty nut is rounded! Don't u just love cars!....................NOT bloody fiats! Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 12, 2009 Share Posted July 12, 2009 This won't help, but: FIAT = fix it again tomorrow. Quote Link to comment Share on other sites More sharing options...
RobD Posted July 12, 2009 Share Posted July 12, 2009 Dont need to take the manifold off at all! Done a fair few sumps on them and not once taking the manifold off! Quote Link to comment Share on other sites More sharing options...
