centreforce dual fiction clutch (num brothers)
Rich8v
Are you still using the same clutch now that you're running a single Si?
What bhp/torque are you running? Is there only one type for the Supra TT, or do they do different max torque rated ones?
Yeh same 1, mine is the dfx iirc, stands for dual friction something, 520 bhp/500ftlb, i think they`re rated to over 600ftlb, no problems here.
Edited by bignum (see edit history)
  • Replies 80
Yeh same 1, mine is the dfx iirc, stands for dual friction something, 520 bhp/500ftlb, i think they`re rated to over 600ftlb, no problems here.this 1,Centerforce Dual Friction Clutch Part#DF510150 for $679.95 shipped to the UK, will be more $ now due to the exchange:(
I use my dual with 676bhp, no problems at all.
Thanks chaps. Do they rattle on idle at all, and how 'heavy' is the clutch peddle?
Hi kev, i also run this clutch with my twins, to be honest mate if i told you it was stock and you drove it you would believe me, its so much like standerd its great, they take a little time to wear in, found it was snatchy to start off with.
Have this clutch on both of my cars, still after 15000km on the red car and 20000km on the black of stupidly fast driving and racing at absolutely insane speeds, still no worries, no slipping, no noise, no effort in driving, just like stock.
Chiefgroover you are the teacher on this.
Really torn between this and the RPS street max :(
I was in the same position, for most people who have the street max, they say its a good clutch. How i made my decision though was, if you do a search no one has had problems with the centreforce clutch. The street max has caused quite a few members problems. And when I read this post by our supra guru, it made the choice easier.
Originally Posted by Chris Wilson
I have had that much trouble with them i won't supply them I'll fit customers own so long as they sign a disclaimer absolving me if it fails to release properly. It's no good lengthening the clutch pedal to master cylinder shaft until the cylinder is under hydraulic pressure and moving the slave and hence release bearing until it touches the cover's fingers. It MAY well give enough movement then to release better, but all you'll achieve long term is a worn out bearing and damaged fingers. There MUST BE free play in the pedal.
Chris Wilson wasn't overly keen on the RPS and it's put me off it, and I've only heard good things about this clutch from some cars with quite a bit of power/torque, so I reckon it'll do me. Pedal feel is apparently light and you also don't have the horrible twin plate rattle.
I was thinking about it, yes, if delivery was fairly quick. Do you have any useful info for me regarding this? :)
I was hoping you might :innocent:
Maybe we could get a dicount on p&p if nothing else?
I've looked on the website and cant find any information on which one to get. What is the dfx unit? Also how many different power ratings are there for the Supra set up?
That lightning performance website is pretty cr@p. I've not found it yet either...
here is a link to the centerforce site
http://www.centerforce.com/clutches.tpl?cart=1248640151319918&subsection=clutchtypes
i couldnt find them on the lightning force site either but they said they can get them no problem. if a few of us want them we may get a discount ?
Sounds like a great idea. What application will you be using it for Dan? Mine will be for a single turbo.
Can the single turbo guys let me know which of the clutches on the above website they went for please.
mine will be on a t67 single. chiefgroover is running a lot of power on his with no problem
