Guest robspan Posted July 10, 2009 Share Posted July 10, 2009 I'm sure this has been asked before but... I've had the supra for 8 years, and about 2 weeks ago when it was very hot, I was driving up a steep hill, and the "O/D OFF" light started flashing every couple of seconds. I clicked the O/D button on & off, parked & turned the engine off & on a couple of times, no luck ! So it was flashing for the next couple of hours until I got home. But since then, no flashing at all... Could there be a loose wire ? Is there a timer so the car has to be off for a while before the warning light resets ? Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted July 10, 2009 Share Posted July 10, 2009 Maybe this should be moved to Technical. Quote Link to comment Share on other sites More sharing options...
Guest robspan Posted July 10, 2009 Share Posted July 10, 2009 can i do that ? Quote Link to comment Share on other sites More sharing options...
Ben-san Posted July 10, 2009 Share Posted July 10, 2009 http://www.mkivsupra.net/vbb/showpost.php?p=426170&postcount=1 Historically, this is is likely to throw up a Speed Sensor fault, or Code 42. Quote Link to comment Share on other sites More sharing options...
Guest robspan Posted July 10, 2009 Share Posted July 10, 2009 if i get the warning again, I'll go through the techie stuff, but it seemed strange to happen only that once, and that was 2 weeks ago ! Quote Link to comment Share on other sites More sharing options...
danhicks22 Posted July 10, 2009 Share Posted July 10, 2009 Mine used to flash when my speedo converter was wired up wrong and I hit full boost. Not sure why but it would be fine driving normally for a while but if I booted it, the light would start flashing and I'd get the biug warning light. A couple of times it just came on without me doing that though... It hasn't done it since I connected the converter up properly. Quote Link to comment Share on other sites More sharing options...
dude Posted July 10, 2009 Share Posted July 10, 2009 It will flash if you have a TRAC problem Quote Link to comment Share on other sites More sharing options...
Abz Posted July 10, 2009 Share Posted July 10, 2009 Mine flash a few times when I replaced the dash, I presume it was a loose wire which was touching because it has not done it since! I would look under the gearbox area to check wires etc Quote Link to comment Share on other sites More sharing options...
