Tricky-Ricky Posted July 10, 2009 Share Posted July 10, 2009 I would be inclined to use a pressure gauge, rather than rely on the light, just a thought have you got a sandwich or take off plate on there? if so you could try removing one of the bungs or sensors and pump some oil in there to re prime. Link to comment Share on other sites More sharing options...
csa Posted July 10, 2009 Share Posted July 10, 2009 yeah get an oil press gauge to do your readings. I had this problem as well with my new engeine. turned and turned it forever without getting pressure. In the end I tried to fill up my oil cooler hoses with oil and it did the trick. but if you havent got an oilcooler...then I dont really know what to do Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 10, 2009 Share Posted July 10, 2009 Towing will work unless there's a bad leak on the suction side of the pump. Link to comment Share on other sites More sharing options...
Smallshinyant Posted July 10, 2009 Share Posted July 10, 2009 i cant provide any helpful info, but i want to know how this turns out.. any news yet? Link to comment Share on other sites More sharing options...
David Reid Posted July 10, 2009 Share Posted July 10, 2009 I had a zetec I rebuilt which appear not to build oil pressure, it was crap in the sender at the end of the day. A replacement cured it. I also had a very tight fast road A series that wouldn't turn the light off cranking at idle. after a rebuild. I fired it up and it went straight off (But Chris's suggestion is a bit safer if more hassle) . Link to comment Share on other sites More sharing options...
JODY T Posted July 10, 2009 Author Share Posted July 10, 2009 I'm gonna remove the engine this week end, I'm gonna replace all the o rings and seals on the oil pick up.. I'm sure it is right but as with anything I'm now loosing confidence and what if has set in.. I really don't want to start it, coz with my luck ide blow it up.. Whilst the engine is out I will pre fill the pump and surrounding pipes I can get to.. I'm hoping something will become obvious.. I'll try and get oil pressure with the engine on the floor, by rigging up a battery to the starter.. But before that I'm gonna check pressure with a gauge tonight, but the pump is not moving any oil so I'm expecting to see no pressure.. If u see no pressure at all, can I assume it's a big leak on the pick up or the pumps not pumping at all.. Is my thinking correct? Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 10, 2009 Share Posted July 10, 2009 Just try towing it first! So long as you lubed the bearings well, and with no plugs, the bearings won't come to harm turning it for a few seconds at speed. Link to comment Share on other sites More sharing options...
absz Posted July 10, 2009 Share Posted July 10, 2009 you can always remove the oil pressure regulator nut and pour oil down which will go directly into the oil pump. it means all the timing covers will have to come off to gain acess. IF you go down that route do not over tighten the nut when putting back together as it only seals on a o-ring and can easily crack the oil pump casting if over tightend. Link to comment Share on other sites More sharing options...
Kranz Posted July 10, 2009 Share Posted July 10, 2009 Can you get an electric pump, or even a pump attachment to a drill and use that to prime the system through the oil pressure switch? About an hour to do as a guess. Then crank it with the pump attached and you'll get oil pressure! Remove the external pump and crank again... it'll work Link to comment Share on other sites More sharing options...
JODY T Posted July 10, 2009 Author Share Posted July 10, 2009 Ive done as Chris mentioned re towing it.. Towed it to 20mph and slowly released the clutch, Hey presto the oil light went out So i came home with a I then fitted the plugs, coil packs, reconnected the fuel supply etc etc and tried to start.. It started first time the oil pressure light went out which was great, Its sounds like a 2JZ should which again was good BUT i have NO throttle control. Also the oil level light came on but I know its got 5.5Litres of oil (and i checked the level it was a little under the full mark) The engine management light came on straight away and its gone into limp mode (revs at 2.5k) with no throttle responce... Im assuming its because the car is a pre VVTI shell and the car loom is different ( I have one plug on the engine loom that i cant plug into anything as its not there.. I assumed it was sonething to do with the tiptronics but maybe i should guess again... I also dont have a trac button so it could be sencing that too... I cant find anything re this so my first thought is to get a new car loom and fit that. (Big Job but straight forward) Has anyone herd of this before? I guess this is why people dont fit VVTIs to older cars lol.. But i like to be a bit different.. Solve one problem and get another, Still at least im Big Up to Chris Wilson!!!! Link to comment Share on other sites More sharing options...
Kranz Posted July 10, 2009 Share Posted July 10, 2009 Props to the homie CW Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 11, 2009 Share Posted July 11, 2009 Ive done as Chris mentioned re towing it.. Towed it to 20mph and slowly released the clutch, Hey presto the oil light went out So i came home with a I then fitted the plugs, coil packs, reconnected the fuel supply etc etc and tried to start.. It started first time the oil pressure light went out which was great, Its sounds like a 2JZ should which again was good BUT i have NO throttle control. Also the oil level light came on but I know its got 5.5Litres of oil (and i checked the level it was a little under the full mark) The engine management light came on straight away and its gone into limp mode (revs at 2.5k) with no throttle responce... Im assuming its because the car is a pre VVTI shell and the car loom is different ( I have one plug on the engine loom that i cant plug into anything as its not there.. I assumed it was sonething to do with the tiptronics but maybe i should guess again... I also dont have a trac button so it could be sencing that too... I cant find anything re this so my first thought is to get a new car loom and fit that. (Big Job but straight forward) Has anyone herd of this before? I guess this is why people dont fit VVTIs to older cars lol.. But i like to be a bit different.. Solve one problem and get another, Still at least im Big Up to Chris Wilson!!!! Doesn't the VVTI have electronic throttle? or have you fitted a pre VVTI throttle body? Link to comment Share on other sites More sharing options...
JODY T Posted July 11, 2009 Author Share Posted July 11, 2009 Yes it does FLy By Wire... Obviously it has sences something wrong.. Could be the cam timing as i can get no definitive answer of how do actually do it.. I went with the fully clockwise approach and the engine does sound nice But the Mil Light was on straight away.. It could also be the fack that i have no Traction control, Ie the car loom is different and i have one plug in the footwell that i cannot plug into anything.. Its the White one (there is a Grey one too, thats pluged in) That i cant plug in.. Anyone know what it is? What it does? Think i need to find a scanner to borrow or Hire.. Anyone know of one? Link to comment Share on other sites More sharing options...
MarkR Posted July 11, 2009 Share Posted July 11, 2009 The VVTI hates the traction control being disabled... Stuffs it right up. You could always try pulling the trac fuse, and if nothing changes then you know that the trac isn't connected? Link to comment Share on other sites More sharing options...
MarkR Posted July 11, 2009 Share Posted July 11, 2009 I'm at work otherwise I could check the plugs in the footwell.... sorry dude. Link to comment Share on other sites More sharing options...
JustGav Posted July 11, 2009 Share Posted July 11, 2009 Did you reloom the interior of the car with the VVTI loom? I remember struggling with the plugs as well. The throttle is very funny at shutting things down when it picks up problems. Link to comment Share on other sites More sharing options...
JODY T Posted July 11, 2009 Author Share Posted July 11, 2009 I dont have a Trac fuze cos the car was originally a 96 facelift NA 6Speed.. No i havent swapped the car loom, I have a tiptronic loom that i modified so it would work with a Manual box.. That works great.. I managed to plug in every plug except the white one.. I assumed it was for tiptroic/traction control etc but i dont know for definate.. IT could just be the cam timing incorrect as i cant get a proper answer on this either... I went for fully counter clockwise on the intake.. Is that correct? If i can find a car loom ill fit it, but still trying work arounds.. Link to comment Share on other sites More sharing options...
MarkR Posted July 11, 2009 Share Posted July 11, 2009 I dont have a Trac fuze cos the car was originally a 96 facelift NA 6Speed.. That could be a bit of an issue. Mine wouldn't even start without the fuse. No i havent swapped the car loom, I have a tiptronic loom that i modified so it would work with a Manual box.. That works great.. Does the piece of loom you sent me in the post work for the manual then? I'm going to try it next week as I've been really snowed at work. IT could just be the cam timing incorrect as i cant get a proper answer on this either... I went for fully counter clockwise on the intake.. Is that correct? Not sure on this, sorry bud. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 11, 2009 Share Posted July 11, 2009 Surly using a non VVTI ECU/loom with a VVTI fly by wire throttle is going to stuff it up,thats why i asked if the throttle had been changed, or have i got the wrong end of the stick? Also is the VVTI mechanism reliant on throttle position for its adjustment? Link to comment Share on other sites More sharing options...
JODY T Posted July 11, 2009 Author Share Posted July 11, 2009 No Im using a VVTI engine Loom and ECU with the VVTI engine.. THe THrottle is controlled by a cable from the pedal to the throttle pot where a petentiometer controls the butterfly.. And Yes the Loom i gave you will fit.. However you will have to fit it on the car side of the loom on the orange plug then itll work lovely... anyone want a free vvti cambelt change lol i could find out then Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 12, 2009 Share Posted July 12, 2009 The VVTi uses two pots, each referencing each other as a fail safe. It's a bit of a nightmare, and something I am totally unqualified to help you with, sorry. Glad the oil pressure is sorted though, cheers. Link to comment Share on other sites More sharing options...
scoooby slayer Posted May 27, 2011 Share Posted May 27, 2011 the starter wont turn it over fast enough for the pump to get oil to the gauge, ive been here 10 years ago when i built my first engine all it does is kill the starter motor, just start it and if it doesnt pick up pressure within 3 seconds stop it as you have a problem. Link to comment Share on other sites More sharing options...
