Cant Get Oil Pressure on New engine
JODY T
Was ready for start up today..
Engine has been rebuit, Removed Plugs and disconnected fuel pump, turned it over but the Fing oil light wont go out..
Ive removed the oil filter, it was dry.. Filled with oil and refitted.. Still Nothing..
Oil Pump is new..
Ive done loads of these engines and this has never happened.. Had to do it on Mine eh..
Anyone got any ideas? Dont want to damage the bloody thing!
Cheers
JOdy T
nah didnt prime it coz the MR T hand book didnt say i had to...
If it was a single i would back feed through the Turbo but its got stock twins.. I will have ago with the oil filter...
Cranking 20sec waiting a bit and then going again
Yeah that is bad that the manual doesnt mention that, you should always fill the pump with oil other wise when you first turn it over the pump runs dry and can damage it.
You could try taking the cam covers off pouring some oil accross the top then try again.
Will try that tomorrow, Might try and get some oil into the hole where the pressure sensor goes too...
I had this on my VW 5 cylinder engine I rebuilt.
Just as CW says I fashioned up an oil feed system that I plugged in to the oil pressure sensor hole. I gave it pressurised feed via compressed air (through a regulator) that pressurised an oil can that fed the galleries with oil.
Primed the system and got it pressurised nicely :D
unforunatly i dont have access to that sort of equipment.... Its worrying me a bit coz i dont want to damage the engine...
Im usually a calm person but this has me riled, Ive just about had enough of supras! And to top it off i was putting my tools away, picked up my socket set and it wasnt locked and it all fell on the floor! Its a big set too!
just tried to back feed the oil in through the hole where the pressure sensor goes...
GUess wat
It did F' all
Next and last option remove the cam covers and pour a load of oil in and hope...
I dont know what else to do..
Pouring oil in the cam covers will do sod all. You need to pressurise the oil galleries. If frustration has really set in tow the thing down the road at 30 MPH, in 5th gear, with the plugs out. If that shows no oil pressure a spilt socket set is the least of your problems :) Good luck!
Tow the thing, BUT, no with plugs, to keep the compression and bearing loads as low as possible. It should be fine. As far as zero oi pressure on a new pump is concerned, and assuming the relief valve isn't stuck open, which is VERY unlikely, less than 1% I'd say. Stay calm. Are you sure the oil pressure switch is working correctly?
I wasnt sure at first so i rigged up a test light to confirm if the car light was correct.. Which it was, just for piece of mind i replaced it anyway.. After turning the engine over without plugs and it not getting pressure i removed the oil filter and it was dry.. So i dont think the pump is moving any oil atall...
The oil feed pipe is straight forward to fit, i used new gaskets and torqued correctly (the strainer thing is completly clean) So if it has oil i cant see how it wouldnt pick it up assuming the above is good..
Think ill Tow it tommorow as a last gasp attemt, Im all out of options :(
Thanks Chris
