jazz1 Posted July 8, 2009 Share Posted July 8, 2009 Ok i know LeeP has done alot of internal build as in pistons etc, what about the rest of the single guys do you just bolt on the kit and thats it? whats the difference? is it much better to upgrade all internal parts etc? Quote Link to comment Share on other sites More sharing options...
michael Posted July 8, 2009 Share Posted July 8, 2009 Join Date: Jun 2005 How have you managed to avoid all the previous threads on this kind of stuff for 4 years? People take both routes, it depends on budget and goals a lot of the time. Quote Link to comment Share on other sites More sharing options...
kslb Posted July 8, 2009 Share Posted July 8, 2009 Mines a built engine, i didn't consider the bolt on and go route just did it the way I thought was right. Quote Link to comment Share on other sites More sharing options...
wkdtime Posted July 8, 2009 Share Posted July 8, 2009 Ok i know LeeP has done alot of internal build as in pistons etc, what about the rest of the single guys do you just bolt on the kit and thats it? whats the difference? is it much better to upgrade all internal parts etc? If you go for the bolt on option you are going to have to budget for around £10k ish Turbo Kit (Turbo, DP, Manifold, Lines etc) Fuel Kit (Fuel rail, Pumps, Injectors, FPR, Lines etc) Supportive Mods (Bigger brakes, BC, AFR gauge, Cooling etc) Mapping (ECU, Mapping, Dyno) Labour for all the above. Quote Link to comment Share on other sites More sharing options...
bonus_2000 Posted July 8, 2009 Share Posted July 8, 2009 Mines a built engine, i didn't consider the bolt on and go route just did it the way I thought was right. I did the same as that Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 8, 2009 Share Posted July 8, 2009 I have no experience of single turbos but i have read lots of threads of personal experiences of single owners with stock internals (Robbie, Jamie P Ian C) and i would say go with the "if it ain't broke don't fix it" approach. Jamie P's latest single was a low mileage stock car and still on the unopened block. A rebuild is heavily reliant on a quality builder and you'd probably be better off killing a high mile stock engine and then (if you can find one) fitting a known low mile replacement. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 8, 2009 Author Share Posted July 8, 2009 id probably go with internals aswell just for the peace and mind Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted July 8, 2009 Share Posted July 8, 2009 (edited) id probably go with internals aswell just for the peace and mind I feel the complete opposite should I ever do it again, a well looked after stock unopened engine will be fine for insane road power, and a lot cheaper that a WELL BUILT engine Only addition would be Cams for me Edited July 8, 2009 by tooquicktostop (see edit history) Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 8, 2009 Share Posted July 8, 2009 Read this and in particular "Robbie" 's comments. He does not post much on here but has had a highly tuned single for many years and has been through the whole rebuild up uprated internals thing and using a good secondhand stock block thing. He is the voice of experience IMO Quote Link to comment Share on other sites More sharing options...
magictorch Posted July 8, 2009 Share Posted July 8, 2009 Mines going on a stock engine:) Lee gave my car a clean bill of health and its a low milage car....im sure Lee will give the once over again tho:) Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted July 8, 2009 Share Posted July 8, 2009 Jazz do I remember you engine has an issue with compression though?? I would not add a single to a poor compression engine without sorting the problem first Quote Link to comment Share on other sites More sharing options...
dude Posted July 8, 2009 Share Posted July 8, 2009 My old silver car was stock with all ARP bolts!!!! Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 8, 2009 Author Share Posted July 8, 2009 Jazz do I remember you engine has an issue with compression though?? I would not add a single to a poor compression engine without sorting the problem first yea my car did hence why i would do complete internal build but you have to understand its only valve related as my car has not been driven in 9 years. It must be sticky or carbon build up as LeeP did leak down test and the gasket was fine aswell as the pistons. LeeP gave it some treatment iv been driving it regular and will do another compression in couple months to see if it clears Quote Link to comment Share on other sites More sharing options...
hodge Posted July 8, 2009 Share Posted July 8, 2009 my engine lets say broke on stock turbos so i rebuilt it with stock internals with no problems at all running a huge single. Like the previous post if its not broke dont fix it. If you do decide to rebuild it make sure You pick a GOOD engine builder or as i did do it yourself an be very maticulious in my opinion its the only way ull no its done right. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 8, 2009 Author Share Posted July 8, 2009 my engine lets say broke on stock turbos so i rebuilt it with stock internals with no problems at all running a huge single. Like the previous post if its not broke dont fix it. If you do decide to rebuild it make sure You pick a GOOD engine builder or as i did do it yourself an be very maticulious in my opinion its the only way ull no its done right. I turst LeeP that guys treated my car like it was his own Quote Link to comment Share on other sites More sharing options...
hodge Posted July 8, 2009 Share Posted July 8, 2009 funny you should say that cos i heard alot of people mention the quality of his work was 1st class. If his own supra is anything to go by you wont go far wrong matey. Quote Link to comment Share on other sites More sharing options...
rob wild Posted July 8, 2009 Share Posted July 8, 2009 I've been single for over 3 years with no engine problems. My top end has been rebuilt with new valve stem seals and hks cams. I think a lot of it comes down to the mapping and making sure that its mapped safely. I will at some point have it rebuilt but hopefully not any time soon. Another good 'test' or example is JamieP's new project which he has done lots of miles, track, drag, drift and general 'Jamieness' and the stock engine seems to be holding up well. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted July 8, 2009 Share Posted July 8, 2009 I think chingy's car is also on stock internals. (I'm sure I read that in a magazine ) Quote Link to comment Share on other sites More sharing options...
bignum Posted July 8, 2009 Share Posted July 8, 2009 As long as your engine is healthy ie good compression, not using oil it should take 600hp all day long, what kills engines is revs, anything above 7000rpm on a stock engine is playing with fire imo. Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 8, 2009 Share Posted July 8, 2009 Yup as others have said, if its healthy leave it stock, mine is upto 65k now, running lots of boost and still going strong, if it was to fail tomorrow id put another stock engine in i think. I think chingy's car is also on stock internals. (I'm sure I read that in a magazine ) Correct. Quote Link to comment Share on other sites More sharing options...
Homer Posted July 8, 2009 Share Posted July 8, 2009 And yet again - stock is fine unless you're going for crazy HP figures or rpm. My old one has been single for about 3 years now, done a lot of miles and used as a daily driver on the stock, unopened engine. With your car (It's only done about 15k hasn't it?) it'd be mad to rebuild the engine. Quote Link to comment Share on other sites More sharing options...
Lee P Posted July 8, 2009 Share Posted July 8, 2009 As everyone has already said only build the engine if it has a problem or you want more than 750hp, you can cause more problems than you solve opening it up. Before you go single we can do a full leakdown test to see whats going on in there, I hope that its improved a bit since last time. Dont forget to put your foot down now and again Quote Link to comment Share on other sites More sharing options...
imi Posted July 8, 2009 Share Posted July 8, 2009 mines had the head done (valve stem seals, uprated cams, etc) by pheonix 18 months ago when I went for a T61DBB (spec in my garage), been my daily driver, pushing 560 @ 1.4bar (mapped by ryan) and seems to be a happy chappy. we didnt touch the bottom end cause it was in excellent condition Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 9, 2009 Author Share Posted July 9, 2009 As everyone has already said only build the engine if it has a problem or you want more than 750hp, you can cause more problems than you solve opening it up. Before you go single we can do a full leakdown test to see whats going on in there, I hope that its improved a bit since last time. Dont forget to put your foot down now and again yea i have been driving it more and putting my foot down il give it another test to see how it goes in next couple months thanks alot for your help LeeP will be in touch again soon:) Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 9, 2009 Author Share Posted July 9, 2009 Thanks guys for the information Quote Link to comment Share on other sites More sharing options...
