Guest champ_supra Posted July 4, 2009 Share Posted July 4, 2009 Hey Guys! I recently had a problem with my throttle control valve being out of position, so managed to brave fixing it and resetting the ECU and it appears to have worked, it now idols nicely at 900 revs.............. But now I have noticed that my fuel consumption has gone up! I've used just about quarter of a tank this weekend and I haven't covered many miles at all, maybe 30 - 50 miles! Is this right?? Usually my fuel is better then that? Have I opened the throttle control valve too much or is it something else completely?? Thanks Kate (1993 Toyota Supra Twin Turbo) Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted July 4, 2009 Share Posted July 4, 2009 What exactly did you adjust? I don't think the idle speed control valve is adjustable, it just might need cleaning out, but I don't think you can adjust it. The throttle position sensor is adjustable, but you shouldn't ever have to touch it. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 5, 2009 Share Posted July 5, 2009 If you have moved the throttle position sensor to try and fix a fast idle the ecu will now be getting incorrect signals in regard to throttle openings, and the engine may well drink fuel. Quote Link to comment Share on other sites More sharing options...
Branners Posted July 5, 2009 Share Posted July 5, 2009 isnt a 900rpm a bit high for an idle anyway? Quote Link to comment Share on other sites More sharing options...
heckler Posted July 5, 2009 Share Posted July 5, 2009 isnt a 900rpm a bit high for an idle anyway? thought its was 650-700? Quote Link to comment Share on other sites More sharing options...
