E-manage question
Kearney
Lads I bought an E-manage Blue today off a mate of mine for my car. He bought it brand new 2 years ago but hasn't used it as he sold the car on BUT in the box there is only one wiring loom. Is there ment to be two? Another question, The 2JZ-GE is not listed only the 2JZ-GTE. Could I get away with using the GTE loom diagram? I'm fitting it for an N/A-T conversion. Any help would be greatly appreciated
are you getting confused with a fields harness (this is an adaptor to plug direct into your ecu - sorry if you already know this) there is one main harness that plugs into the emanage that then needs either the fields harness or splicing into the ecu loom, i dont know about the n/a harness but it will be different to the TT, you will have to get an n/a ecu diagram and then match it to the connections in the emanage manual, i think this is a rare mod as no one usually mods the n/a to the point where they need fuel/ ignition adjustment so you may be on your own
  • 2 weeks later...
