12v Timer Thingy
jevansio
Can anyone tell me if what I want to do is possible. Basically my electric fans are controlled via a relay when the ignition is switched on. What I want is a delay (say 10 sec) when the fans come on after the ignition is swicthed on. Is there a simple component I can buy that you just put a 12v ignition feed in one side & you get 12v out the other side 10 sec later.
Guest P13SST
Why would you want to do this out of curiosity? Most fans run at 6v per fan at low speed.
To make your self with a resister, transistor and capacitor through a reverse connected base junction... i.e. a pain in the ass. I would imagine this type of component would exist in some household gadgets...
I'm moving to a Varley Red Top 25 battery as my car is basically a road going track car (no ac, heater, stereo etc). I don't want any additional strain on the battery when I crank it over, I want the fans to start after the motor is running
Guest P13SST
Lol, mines ain't that great either but i like switches :s, makes me feel in control.
Well tbh, it would save you 'building' one your self which may take an hour or so of your time so is your time worth more? Plus its likely going to have a tidier appearance than DIY wiring.
Jay, I've used two of the outputs on the ECU to switch the relays when the water gets up to temperature. It's really not that difficult :) I even fitted two LED's so I know when the fans come on.
Yeah I know that's how Ryan usually does it, does that mean your fans are on before cranking if you're doing a warm start, I want to avoid anything being on before the motor is running due to choosing a low capacity battery?
An automatic switch (no matter how untidy) will be tidier than a manual one though :), I thought this sort of thing would be an off the shelf item?
Good point. They would still come on with the ignition if the water was up to temperature. Only thing I would say, is that the engine should be easier to turn over if it's warm right?
I believe you have the same fans as me, which drew 8 Amps each when first started (dropping considerably once going).
It prolly not an issue when carrying a big battery, yeah same fans. Wonder if I'm being too apprehensive. Pretty sure Wez runs the Varley 25, might see if he's had any issues so far
It shouldn't be that difficult to install a timer relay, just to be on the safe side. It's only a tenner... :)
  • 2 weeks later...
