What to do?
Vaughany
Sorry for the long post but I need to set the scene. I have been building my Supra for the last three years, here is a link to my garage for photos and current spec.
http://www.mkivsupra.net/vbb/vbpicgallery.php?do=view&g=1991
The car made 591bhp at the fly at 1.75bar which was ok but I decided to get the head ported and polished to see what improvements this made. After this was completed the car was took to Mark Shead for mapping.
Unfortunately on the road run at 1.6 bar a water hose popped off and we feared the worse as the temp gauge maxed out. The car was stopped immediately to minimise any damage. After letting the car cool down, refilled the radiator the car was taken out and driven steadily to see how it drove. All indications were good, temps were back to normal at normal driving and there was no obvious signs from driving to make us think there was a problem.
After road mapping I continued to get a single power run on a Dyno Dynamics dyno. The car made 516bhp at the fly which was obviously 75bhp down on the last power run prior to porting and polishing of the head. I was obviously upset and seeked answers to why the power had dropped. It seems the brief overheating has caused some damage. A compression test confirmed this with the following readings
piston 1 150
piston 2 150
piston 3 150
piston 4 140
piston 5 131
piston 6 130
Actual diagnosis for the exact problem still needs to be confirmed but indications are that at best I need new piston rings, at worse, new pistons and rings. So is suppose anywhere between £2000 - £4000 to repair.
I have had enough of the car now and have decided to sell, my questions are the following
  1. Should I repair the car in full,mapping and power run and then sell?
  2. Should I sell the car as it is with a obvious price reduction?
  3. What would the car be worth in a fixed state?
  4. What would it be worth as it stands?
Dont really want to break and sell the parts as it will take to long. The car was built from an empty shell upwards and has an extensive build including full respray and currently owes me in the region of £40k:(
Please advise as I have lost faith!
Thanks
Get it repaired and sell it mate if you have had enough. You have a STUNNING car. With some very nice parts. It would take a long time and a lot of effort to brake.
I saw it outside halfords a few months back and still looked great.
If you wanted to brake it i'd take the tubby kit off you but i dont have the money :(
gutted for you :(
It will always be worth more being fully functional. It would make sense to fix it and then sell it if you so wish, the fact of the matter is, you won't see 40k, but you would see something realistic.
Hi Gav
Yeh i know it makes sense to fix it but what do you think a realistic price would be? f i could get £10k as it is and £14k as repaired, I could see the worth in fixing it especially if the damage isd not horrendous.
What do you think it would be worth in a fully functional state - I was hoping for £16k - realistic or not?
Hi Gav
Hmmm, it could go offshore for more. Perhaps have a word with Jurgen, given the amount of work that has gone in, I would have thought it would possibly be worth more.
It is a lovely looking car, stock and has a VERY impressive mod list
Exterior
MKIV Supra UK - No bodykit
Lamboughini Blue Spark
Colour coded Front Active spoiler and Oem trims
Interior
Oem Seats front and Rear, Blue Alcatera and Black leather with Supra logo
Blue Alcatera door cards with black leather
Blue/Black Mats with Supra logo
Levoc Automatic Gear Knob
Levoc Handbrake Handle
Chrome Heater Control buttons
Razo Pedals
Engine and Turbo
PHR Stage 2+ Turbo Kit - T67 Turbo includes HKS 50mm stainless steel header, HKS GT 60mm external wastegate, 65mm 321 stainless steele Dump Tube
HKS Type R BOV
Greddy Oil Catch Can
Veilside Intake with 100mm Throttle Body
Built Engine - Parts used rated to 1000bhp
CP 87mm Pistons
H Beam Carillo Conrods
VP Race Bearings
Balanced and polished crankshaft
Rebored block
Uprated Oil Pump
ARP Big End and Main studs
ARP Rod Bolts
Head Work
HKS 272 Cams Intake and outlet
HKS Adsjustable Cam Gears
Reground Head Valves
1.2mm Gasket
Ported and Polished
Re - Shimmed
PHR 150amps Racing Alternator
Battery Relocated to Boot
Various bits of Bling
Fuelling
Racing 1200cc Fuel Injectors
Twin Motorsport Fuel Pumps
Braided fuel lines
Aeromotive Fuel Pressure Regulator
Cooling
Greddy 4 Row Intercooler
Fluidyne Aluminium Radiator with twin electric fans
Mocal Oil Cooler
Mocal Transmission oil Cooler with electric fan
Transmission
4 speed Automatic Gear Box - Uprated and strengthened
3200 High Stall Torque Converter
Suspension and Handling
Tein Superstreet Coilovers with EDFC
Cusco Strut Brace
Race Logic Traction Control
Exhaust
PHR 3" Downpipe and Midpipe
Blitz Nurspec R Stainless Steele Exhaust system
Electronics
Autronic SMC ECU
Autronic 5000 Direct Fire CDI
Blitz Dual Solenoid SBC - ID 111 Spec R Boost Controller
Greddy Oil Temp Gauge
Greddy Transmission Temp Gauge
AEM Air Fuel Ratio gauge
Blitz Mirror EGT Gauge
Brakes
UK Brakes 4 pots at front and 2 pots at rear
Braided brake lines
5.1 Synthetic Brake Fluid
Wheels and Tyres
Blitz Technospeed Z1 19 X 10 285/35/19 and 19 x 9 245/35/19
ICE
Panasonic CD. MP3 player
VIBE Speakers front and Rear
400watt amplifier
1000 Vibe 12" Base Box and built in Amplifier
Security
Clifford Condcept 650 Alarm/Immobiliser
RAC Tracker
i would say its easily worth 14k. there are some very nice and rare parts on this car. wheels aint cheep. veilside intake. One of the nicest engine bays in the club.
Get it fixed up and ill do you a strait swap then you can have a nice reliable bpu uk spec instead :p
Wahtever happens, the car is definitely going!
It is a shame, as it is a lovely example...
If it were me, I get it checked out properly to diagnose which bits have gone, as it may not be as bad as you think, and I'd still maintain a working car like yours is worth SOO much more than a blown one.
The compression is not that bad, ive seen worse, how do you know its the rings and not a head issue?
Does the car smoke? was is dyno'd on the same dyno?
Being auto i think you will struggle to get good money for it.
Hi Jamie
No smoke, no overheating, some glazing on the bores so possibly rebore and new piston rings i hope. Until the engine is took apart, no way of really knowing.
I would hope £16k would be realistic a few grand for a manual conversion and a high spec manual supra would belong to the new owner.
Hi Jamie
I just dont think there are many people that would spend that sort of money (Gaz1's stunning single 6speed never made that much and was forsale for a long time) on a auto supra in this climate, i hope im wrong though and good luck with what ever you do.
On another note i thought this car made over 700bhp? maybe im getting mixed up with somebody else:)
Edit, no it was you.
http://www.mkivsupra.net/vbb/showthread.php?t=161790
Edited by JamieP (see edit history)
Different dyno mate, 591 on dyno dynamics, i was expecting more hence why head was ported and polished. i was hoping the spec would of produced 600bhp at 1.5/1.6bar but not so laggy
Are you sure the head`s 100%? Valves seating ok?
If it IS pistons/rings wouldn`t a s/h engine work out cheaper?
Not sure mate but my engine had a lot done to it and I am hoping alot of it is still ok to use, not sure what the costs would eb to transfer together with buying a 2nd hand engine
  • 4 weeks later...
Thanks for the advice guys, well i decided to get the engine repaired. On further investigation the damage was not as bad as first thought. The rings were knackered and there was glazing to the pistons caused by overheating due to the water pipe popping off. As we speak all issues are being sorted with new parts and I should have the car back by friday.
The car will be for sale shortly so if anyone is interested prior to the official add, please drop me a PM
Thanks again for the advice
All that hassle for 36-months and you want to sell your pride and joy.
I think your passion will reignite once you have her up and running again
Unless you need the money for other plans then I would certainly consider keeping the Supe.
My previous Supra was stock engine running a PHR Stage 1 - great car with no problems. This one has certaintly been a test. In all honesty I dont want to drive it as I know I will want to keep it. The missus wants to keep the Supe as she is insured on it and loves driving the car.
I have just decided to sell and buy a sensible nice family car, a shame i know but FAMILY first:)
EDIT: I need to read more before posting lol
Ryan
Edited by Ryan.G (see edit history)
Ryan
No worries mate, I thought glazing of the bores and pistons was caused through light loads in the running in phase of an engine build where the rings/valves dont hone properly
On further reading I found that overheating can cause relaxed rings and glazing to the pistons causing low compression. Either way, a aggravation which has been costly to repair. I am surprised that a water pipe slipping off can cause so much damage - :)
I suppose it could have been worse, damage to the HG or head was possible but no damage was found luckily.
