V160 fluid - still the thing to use?
Keith C
Oh look... I did!
http://www.mkivsupra.net/vbb/showthread.php?t=56684
Manual 6-speed V160/161 Gearbox
Stock = Toyota V160 oil (PART No. 08885-01306)
Capacity 1.8l's when dry
Toyota V160 Oil (comes in 1L cans - require 2 cans)
Alternative:
Esso Dextron D21065 - R34 Skyline has same box and uses this, however this too is in short supply
BMW oil called MTF-LT-1 or LT-2 - Feedback required from testers
Castrol Transmax Z - Feedback required from testers
Royal Purple SynchroMax - Feedback required from testers
Mobil ATF 220 - Feedback required from testers
I recommend you stick with stock but in recent times this has been hard to get hold of, so it's the Esso now...
Interval = 2 Years / 30,000miles depending on use/power levels
LSD Diff Oil
Stock = Unknown 75w90 Gear Oil
Capacity ~1.5L's (have 2L's Ready)
75w90 - Motul Gear 300 or Silkolene Syn5
I recommened either of the two listed - both have been used without issue.
See here for details on changing diff oil.
:p
Edited by Alex (see edit history)
I called my local Mr T dealer and gave them the part code for the V160. They said is has indeed been discontinued, but it had a note in the system saying it has been superceded by a Dexron Type IV ATF, which is only £42 for a 5-litre tub! Once I have it I'll let people know the exact spec.
Well I picked it up today, along with a printout of the note in the system regarding it's replacement. The note says:
Part number: 08885 01306
Part description: V160 Gear Oil MTM
RA Code: 7: No longer available in original form
ACS Information: This is the local alternative: ESSO ATF DEXRON type: D21065. / P/N 08886-82025 It used to be available across Europa. (P. Kohut)
So part number 08886-82025 is the replacement, and is a 5 litre tub of ATF type T IV, costing £42.55 +vat - less than a tenner a litre!
Amusingly, the Toyota system has it's description as 'POWER STG FLUID', but the container itself definitely says ATF :)
I think its all the same stuff anyway, isnt this auto fluid then as thats what i put in my auto?
Yes and ive been saying that for years. We had a sup in the other day and the 6 speed had a big sticker from the factory saying ATF only!!!!! Most of the TVR's we have just use Dexron.
I use the same as Keith c and have done for the past year and it's been fine, nice smooth gear change I got it from Steve Manley at toyota he said this is what they have replaced it with now!. I carn't see toyota selling an oil that's going to mess our gear box's up. I would give this oil a :thumbs: up
