Tom Posted July 2, 2009 Share Posted July 2, 2009 Any pro's on here that know how to add a border and text to a load of photos automatically in one hit??? I've got over 500 photos to do and I don't fancy adding them one by one! cheers! Quote Link to comment Share on other sites More sharing options...
Tom Posted July 2, 2009 Author Share Posted July 2, 2009 and perhaps resizing all in one go too? Quote Link to comment Share on other sites More sharing options...
Tom Posted July 2, 2009 Author Share Posted July 2, 2009 nevermind got it sussed, if anyone was interested to know I found this to resize a batch of them dSjWOw5s1Qc Quote Link to comment Share on other sites More sharing options...
colsoop Posted July 2, 2009 Share Posted July 2, 2009 Edit typical i write all that and you get the answer Tom, im no expert but did do this a while back so: Open one image that you want to perform these actions on. On your history Tab, to the left of that is the actions tab. (if it isn't open go to window > actions) Down the bottom of the actions tab you will see an icon that says "create new set" Click that and name the set. Now you want to create actions for that set so go to another icon at the bottom of the action tab labelled as "create new action" Press that and name the action prefereably to what you are about to perform for example "resize image". When you have done that the little record symbol is active so you will then perform the action you require. so now resize the image in the normal way. When you have done that press the stop button. repeat this process for each new action. Now you have your set with each action you need to go to Automate > batch. At the top you will see a drop down box marked as Play simply select your new action and then choose the folder. Thats the jist of it, it may take some playing about as i haven't batched a set for a while. Quote Link to comment Share on other sites More sharing options...
Tom Posted July 2, 2009 Author Share Posted July 2, 2009 cool cheers for that I havent worked out the borders bit yet so hopefully this will work for that! Quote Link to comment Share on other sites More sharing options...
grahamc Posted July 2, 2009 Share Posted July 2, 2009 I use VSO for the resizing, its rather good and just a right click away Quote Link to comment Share on other sites More sharing options...
