Radiator leak K-SEAL the miracle cure?
adam82
Just noticed that my radiator is leaking very slightly onto the undertray and on looking for a replacement radiator found adverts for this stuff... K SEAL http://www.kalimex.co.uk/section.html?secpath=01.04.&pgid=17
So how bad an idea would it be to use this?
My thoughts are that it will no doubt be too good to be true but its ever so slightly tempting rather than forking out for new radiator. :search:
Bad. It either won't work or you'll have something that can seal holes against 15+psi of pressure waltzing around your entire coolant system. Block up or restrict the flow in the clyinder head and you could lose the whole motor.
Where is the leak coming from exactly? It might not be the rad, it might be the overflow from the expansion tank...
-Ian
Well when i look down between the air con condenser and the radiator with a torch i can see a fresh splash of what must be coolant on the fan housing at the back of the radiator.
It looks like it has squirted out from just around the middle of the radiator onto fan housing behind and then seeped down onto the undertray. (Thats what i think it looks like anyway) :-)
New rad in my opinion, not a big fan of these instant fixes out of a bottle, your rad is old so replace it, thats the joys of owning an old car.
Yeah I guess I will go for an ASI Fluidyne style one if I can find one. Oh well more money.
