A Stupid question about brakes
Scott
At the moment i am giving my rear calipers a paint and a general spruce up. So, i notice that there is only one piston in either side of the caliper. On the pads there are 2 circles for where i would presume the pistons are meant to push but mine only has the 1.
Why are they called 2 pot? Are there 2 more pistons behind the main one that is visible?
I know its a bit of a daft question but i would appreciate any info/insight.
I've not moved onto the fronts yet (4pot). Is it much the same with them?
are they uk?
Yes and no, i have a RZ Facelift so they come with the larger brakes as standard. They are japanese but 2pot rears, 4pot fronts.
If you check the pics that Nic has in one of his for sale threads you will see what i mean.
I'll get a pic in a sec...
If you have two pads with one ring on each, you have 2 pot rears. If you had 1 pot sliding calipers you'd only have one ring on the inner pad as the outer pad is squeezed onto the disc by the pad carrier, equal and opposite reaction to the force applied by the piston on the inner side of the disc. Thats why when you get seized rear caliper pins the inner pads wears down and the outer pad has plenty of material left
well a 2-pot calliper had two pistons in it, one from either side to act upon the brake disc, therefore only one piston acting on each brake pad.
Thanks, as above i thought that but that led me to questioning how a 1pot would work lol.
Stupid question now answered :D
