GeordieSteve Posted April 18, 2005 Share Posted April 18, 2005 Anyone know if Power Enterprise 680cc injectors from Vortex will drop straight into the J spec fuel rail or will I be needing another fuel rail and resistor pack? Taa Link to comment Share on other sites More sharing options...
Jake Posted April 18, 2005 Share Posted April 18, 2005 Do you mean 650? The 650cc ones fit the standard rail and don't need a resistor pack. You'll need a SAFC/eManage/etc to trim them of course. Link to comment Share on other sites More sharing options...
Miguel Posted April 18, 2005 Share Posted April 18, 2005 As Jake says direct drop in and no ressitor pack needed. Link to comment Share on other sites More sharing options...
GeordieSteve Posted April 18, 2005 Author Share Posted April 18, 2005 I was told 680 but it could be 650. Hope it is coz I've got the SAFC. Cheers dude Link to comment Share on other sites More sharing options...
Miguel Posted April 18, 2005 Share Posted April 18, 2005 PS 650 Link to comment Share on other sites More sharing options...
baldy Posted April 18, 2005 Share Posted April 18, 2005 for the pe650 which would be better safc or emamage to control fueling cheers baldy Link to comment Share on other sites More sharing options...
GeordieSteve Posted April 18, 2005 Author Share Posted April 18, 2005 Emanage I'd say but it's harder to set up Link to comment Share on other sites More sharing options...
Steve Posted April 18, 2005 Share Posted April 18, 2005 Could you just use a SAFC to control them?? Link to comment Share on other sites More sharing options...
GeordieSteve Posted April 18, 2005 Author Share Posted April 18, 2005 Sure can Link to comment Share on other sites More sharing options...
Alex Posted April 18, 2005 Share Posted April 18, 2005 With any fuel computer you need a WB02 sensor to set it up properly...the eManage's datalogging can make this far easier to map accurately...the S-AFC will be a very rough optimisation based on what you think you see... Anyone in striking distance of Norwich should get an eManage and come see Ian C (Or me lol - I'm getting to grips with it slowly...my head hurts ) Link to comment Share on other sites More sharing options...
Jake Posted April 18, 2005 Share Posted April 18, 2005 Alex, What IYO is the best wideband for use with an e-01 and/or eManage? Thanks Link to comment Share on other sites More sharing options...
Paul Whiffin Posted April 18, 2005 Share Posted April 18, 2005 Go with the AEM WB with display, does the business and looks cool and the gang. Link to comment Share on other sites More sharing options...
Jake Posted April 18, 2005 Share Posted April 18, 2005 Thanks Paul, I'm sure you're right but I'm looking for something to work with the e-01 display really. I don't want any more gauges in the car if possible. I read on here that a lot of the widebands aren't suitable for use with the e-01 though. I'm hoping Alex/SimonB/IanC will already have done their homework on this for me Link to comment Share on other sites More sharing options...
Alex Posted April 18, 2005 Share Posted April 18, 2005 Well any is better than none. I'm afraid I've only had experience of the AEM ones. MVP currently supply the sensor for the 30-4111/4112/4121/4211/4212/4221 AEM gauges which is a Bosch LSU4.2 with a configuration spanning 10:1 to 19.98:1. This is what I have (one of those "30-4xxx" model codes means 52mm black gauge with black bezel). Ian got a slightly different one. 30-2300/2301 again using a Bosch LSU4.2 sensor. This has a different range from 8.41:1 to 19.44:1. AFAIK The second one has a much higher resolultion in the range where you need it 11-13:1. But it costs more and I'm not sure if Dusty can supply it. I'd get the 30-2300/2301 if I could but IMO the one I have 30-4212 (I think) is more than good enough. The 52mm gauge is very responsive and clear to read + it's resolution is more than enough for our needs The WB02 can be datalogged at the sametime as the rest of the eManage datastreams thus making off line mapping easier...I just take a few datalogs on the laptop and sit in my lounge pouring over the data seeing where adjustments are needed.... I'm getting close to needing to dyno it soon I have no experience of the E-01 and what it can or can't display sorry - only laptop tuning for me Link to comment Share on other sites More sharing options...
Jake Posted April 18, 2005 Share Posted April 18, 2005 Thanks Alex. I might try SupraForums to see if I can get any advice from folks who've used the e-01/WB combo. Link to comment Share on other sites More sharing options...
