Power Enterprise Injectors
GeordieSteve
With any fuel computer you need a WB02 sensor to set it up properly...the eManage's datalogging can make this far easier to map accurately...the S-AFC will be a very rough optimisation based on what you think you see...
Anyone in striking distance of Norwich should get an eManage and come see Ian C ;) :thumbs: (Or me lol - I'm getting to grips with it slowly...my head hurts :looney: )
Thanks Paul, I'm sure you're right but I'm looking for something to work with the e-01 display really. I don't want any more gauges in the car if possible.
I read on here that a lot of the widebands aren't suitable for use with the e-01 though. I'm hoping Alex/SimonB/IanC will already have done their homework on this for me :D
Well any is better than none. I'm afraid I've only had experience of the AEM ones.
MVP currently supply the sensor for the 30-4111/4112/4121/4211/4212/4221 AEM gauges which is a Bosch LSU4.2 with a configuration spanning 10:1 to 19.98:1. This is what I have (one of those "30-4xxx" model codes means 52mm black gauge with black bezel).
Ian got a slightly different one. 30-2300/2301 again using a Bosch LSU4.2 sensor. This has a different range from 8.41:1 to 19.44:1.
AFAIK The second one has a much higher resolultion in the range where you need it 11-13:1. But it costs more and I'm not sure if Dusty can supply it.
I'd get the 30-2300/2301 if I could but IMO the one I have 30-4212 (I think) is more than good enough. The 52mm gauge is very responsive and clear to read + it's resolution is more than enough for our needs :D
The WB02 can be datalogged at the sametime as the rest of the eManage datastreams thus making off line mapping easier...I just take a few datalogs on the laptop and sit in my lounge pouring over the data seeing where adjustments are needed....
I'm getting close to needing to dyno it soon ;) :D
I have no experience of the E-01 and what it can or can't display sorry - only laptop tuning for me :)
