Noise rear wheel/brake...
edd_t
Have recently developed a metal on metal 'shhhhh shhhhh' noise from drivers side rear wheel. Its not constant until your brake, then you get a constant shhhhhhh noise. So am guessing it probably not bearing, as when the bearing on the other side went the shhhh shhhh noise carried on when braking (if that makes sense)
Could it be a warped disk maybe? And whats the best way of diagnosing the problem myself?
Cheers,
Edd...
