paulj1 Posted June 28, 2009 Share Posted June 28, 2009 HI I m just about to have wheel alignment done and need all the factory settings for my TT supra can anyone help please as I'm sick of buying new front tyres lol Thanks Paul Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted June 28, 2009 Share Posted June 28, 2009 Not really sure what you are after. When mine went to ProTyre they just aligned on the system Quote Link to comment Share on other sites More sharing options...
SteveR Posted June 28, 2009 Share Posted June 28, 2009 Do you really want stock alignment? (it's a bit granny-like) Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted June 28, 2009 Share Posted June 28, 2009 Are you talking just tracking or camber and caster also If just tracking then any good tyre place should do it right Quote Link to comment Share on other sites More sharing options...
paulj1 Posted June 28, 2009 Author Share Posted June 28, 2009 i'm after camber, caster settings it is going to a friends garage who builds and maintains rally cars but he just asked me to get the factory settings so he has rough idea where to start from then take it from there. Its rubbing insides of all 4 tyres off but its not been done for last 6 years Quote Link to comment Share on other sites More sharing options...
gt4tosupra Posted June 28, 2009 Share Posted June 28, 2009 i'm after camber, caster settings it is going to a friends garage who builds and maintains rally cars but he just asked me to get the factory settings so he has rough idea where to start from then take it from there. Its rubbing insides of all 4 tyres off but its not been done for last 6 years Mines doing the same mate! Took it to get geo done, but need new bushes on rear, which are now on order, PU bushes! And the camber bolts and nuts are costing me £50 from MrT[sHOCK][/sHOCK] Garage said its about -2 degrees at the mo, what difference will i notice if i put it back to factory settings btw? Quote Link to comment Share on other sites More sharing options...
The Restorer Posted June 28, 2009 Share Posted June 28, 2009 To reduce the inside tyre wear on my own car I changed to the Lance W alignment settings. Do a search. Just to add, they worked very well for me with better handling than before. Quote Link to comment Share on other sites More sharing options...
paulj1 Posted June 28, 2009 Author Share Posted June 28, 2009 great stuff thanks for your help I'm running 18 inch rims not sure that makes any difference Quote Link to comment Share on other sites More sharing options...
chrispot Posted June 29, 2009 Share Posted June 29, 2009 HI I m just about to have wheel alignment done and need all the factory settings for my TT supra can anyone help please as I'm sick of buying new front tyres lol Thanks Paul hi paul I want to get my alignment done and found this http://www.mkiv.com/techarticles/lance_alignment/index.html sorry i dont know how to put a link in to this page perhaps you could copy and paste, regards chris Quote Link to comment Share on other sites More sharing options...
paulj1 Posted July 5, 2009 Author Share Posted July 5, 2009 Hi just wanna say thanks for all your help had full geometry set up done by Nation wide crash repair center in Hull they were fantastic took the 4 hours but still only charged £109 including vat feels much more planted and will hopefully get more then 3 months out of a set of tyres Thanks again Quote Link to comment Share on other sites More sharing options...
AJI Posted July 5, 2009 Share Posted July 5, 2009 HI I m just about to have wheel alignment done and need all the factory settings for my TT supra can anyone help please as I'm sick of buying new front tyres lol Thanks Paul If you have factory toyota wheels, tyre sizes and factory coilovers and your Supra has not drastically changed weight then factory alignment settings will be the best for tyre wear versus performance compromise. Each alignment centre should have the factory settings on their computer (or at least on some sort of chart). I would only recommend going for an alternative alignment only if you are (1) wanting to change the handling characteristics of the car or (2) have had some aftermarket suspension or anti-roll bars etc. fitted and/or wheel offsets changed. The factory alignment on a stock car is a good 'safe' set up. Toyota engineered the car to first understeer on corners to let the driver know when the limit is reached.... you don't necesarrily want a setting that oversteers first when the limit is reached. Quote Link to comment Share on other sites More sharing options...
AJI Posted July 5, 2009 Share Posted July 5, 2009 ah...just realised that you have already had an alignment done... what settings did you request in the end? Quote Link to comment Share on other sites More sharing options...
paulj1 Posted July 6, 2009 Author Share Posted July 6, 2009 they had factory settings on their machine and adjusted it slightly got reading some where so I'll have to have a look but it was miles out. got new tyres today too feels so much better Quote Link to comment Share on other sites More sharing options...
