Heater foam blowing through air vents
Guest Pebble head
Guest Pebble head
Has anyone experienced the sandstorm of breaking up heater foam gasket as i do with my 93, j spec n/a .... its got so bad that bits occasionally get stuck in my eyes while driving.
Is there a particular sealing foam gasket that breaks up ?
I,ve also noticed the that when the heater control is on its cool setting the air coming through is still quite a bit warmer than the outside temps ?
I have had the same problem.
Here we go: http://www.mkivsupra.net/vbb/showthread.php?t=184058
